Reply 20 of 23, by ArcadEd
pentiumspeed wrote on 2021-12-30, 23:46:
Progress! 😀
This looks like horizontal sync signal not making through properly or clean enough. Keep checking these components that was wet from the capacitor juice.
Cheers,
There is a POT that seems to have some corrosion on it. I have to assume those can be effected as well.
I'll try to find it in the schematics and see what it's for.
I found a few bad components around there including a cap that had leaked.
Reply 22 of 23, by ArcadEd
superchill wrote on 2022-10-19, 18:42:
Any update on this? Seems like I have a similar issue...
I haven't had the time to get back into it. It's not the easiest monitor to disassemble and reassemble 😀
Please post here if you have any luck though.
Reply 23 of 23, by pentiumspeed
Need to inspect all the capacitors to make sure there is no corrosive juice leaking out. Usually from brown ones.
Cheers,
Great Northern aka Canada.
