First post, by rad_sci_guy
I'm having a problem getting a compact flash drive on IDE adapter to work together with a standard IDE hard drive on the same IDE cable. Connected separately they both work well but when i have both attached I can't get both drives to show up in the bios. Is it possible to run both on the same cable?
