First post, by rad_sci_guy
I'm having a problem getting a compact flash drive on IDE adapter to work together with a standard IDE hard drive on the same IDE cable. Connected separately they both work well but when i have both attached I can't get both drives to show up in the bios. Is it possible to run both on the same cable?
Reply 1 of 2, by RetroGamer4Ever
Unless the adapter has a jumper for Master/Slave, you can't run them on the same cable.
Reply 2 of 2, by rad_sci_guy
Thanks RetroGamer4Ever
I didn't even see the jumper setting for the master/slave on the card. it's working now.
