First post, by my03
i have this nice Toshiba 480CDT that i use more or less for retro gaming (its a beautiful machine for that purpose). I have recently replaced the speakers on it (left one did not emit sound, so i replaced both of them with a pair of Arduino speakers (28mm variety). Before this i also upgraded the ram to 168mb (yes, overkill, but why not..?). I'm currently running a 8GB industrial CF on it (paired with a Syba dual CF 2.5 enclosure - where only the master is supported supposedly). It works fine. But i'm now heading towards upgrading the HDD as i'm close to run out of space.
But here is my question: Is this model similar to the Libretto in that it actually DOES support >8GB but with the caveat that you have to leave a section of the disk between 8GB - 8.2GB (rougly) unformatted? I had to do that on the Libretto 110ct when i installed a 16GB drive on it to make it work properly (for reasons that eludes me atm). I recall that if i tried to have continuous space around the 8GB mark, the drive tended to become corrupted rather quickly.
As the 480 and 110CT are basically very much alike (cpu, etc) but of course of different size, i wonder if the "bigger" brother suffers from the same issue in this regard? Anyone know?
