First post, by dfaber1
Hello,
My Gigabyte GA-6VXE7+ just died. It ill not power up at all with a good PSU. No apparent visual damage. When I check the power rails, I see that +5vsb is connected to ground. All the others are not shorted. Any idea which component could be shorted?
Thanks.
Reply 1 of 27, by Nexxen
dfaber1 wrote on 2022-12-11, 22:28:
Hello,
Thanks.
Post pictures in HQ.
Probably some dead mosfet, it's not that simple though.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 2 of 27, by darry
Hello,
Thanks.
What PSU was it connected to it when it died.
Was it one of these Re: A tale of two PSUs ( Fortrex , Deer or similar rebrand with a similar 5VSB design ) ?
Reply 3 of 27, by Sphere478
darry wrote on 2022-12-11, 23:41:
Hello,
Thanks.
Oh dear Odin….
If ever there was a cautionary tale to test on a really good psu checker there it is!
I recently got a nice digital one that shows alp the voltages. Good investment.
Sphere's PCB projects.
Reply 4 of 27, by dfaber1
The PSU did die at the same time. Most likely took the MB with it. I tested with a known good PSU and the MB won't even power or post. I've removed and checked the LX8384 and it does not seem to be shorted. I've checked the 2 MOSFET K3296 without remove them from the board, but they don't seem to be shorted either. All the caps look Ok, no bulge or leaking. Here are some pictures.
1.27 MiB
MB3
1.89 MiB
MB2
1.58 MiB
MB1
Reply 5 of 27, by dfaber1
This fault is driving me crazy. +5vsb is grounded for some reason. I've checked every component that I can check and none seem to be shorted. There are 2 capacitor and a regulator that have there pins to ground also but I have removed them and tested them and they are good. The pads re still grounded even when the components marked in red are removed. Unless the issue is in the chipset, any idea where I can look?
698.86 KiB
Reply 6 of 27, by treeman
You could cut the rail where it goes to the chipset and see if it is still shorted, if not just solder that section back on, then repeat again as u cut sections off the 5v rail and test them all for short. Hopefully u can isolate which section is grounded and what exactly is connected to it
Reply 8 of 27, by dfaber1
I tried to inject power on the +5vsb pin with the bench PSU and nothing is warming up. I cranked the amp up to 1 and only used around 200 mA at 5v. I think that I will mark this board as dead and use it for parts unless someone has another idea.
Thanks.
Reply 10 of 27, by treeman
Cut the 5v line to the chipset, like its been said its dead anyway and only takes 2 seconds to make a solder bridge over it if you need it back
Reply 12 of 27, by treeman
Yeah if its the bga czip forget about it, thats why I said quick way to determine it since you mentioned it might be czipset that is shorted
Reply 13 of 27, by Hoping
Well, did somebody notice the estrange color in the middle of the super IO chip? Or my eyes are playing with me, or is because of the photo.
The one on the bottom left of the board that has Gigabyte written on it.
Reply 14 of 27, by dfaber1
Hoping wrote on 2022-12-17, 16:49:
Here are some close up pictures of the IC. Since the board is dead anyway, I think that I will start to de-solder parts to try and find out which one is shorted.
1.41 MiB
1.16 MiB
Reply 15 of 27, by Roman555
dfaber1 wrote on 2022-12-18, 14:37:
Here are some close up pictures of the IC. Since the board is dead anyway, I think that I will start to de-solder parts to try a […]
Check PS/2 connectors and for diagnostic matter remove jumpers that switch power (+5VSB or +5V) for KB/MS
    gigabyte_ga-686vxe_plus.pdf
    599.84 KiB
    33 downloads
    GA-6VXE+ schematic diagram
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 16 of 27, by Hoping
That chip is fairly easy to remove with hot air, it is powered by the 5vsb to control the pson I think. You can also check the diodes around the ATX power supply conector, maybe there's one for the 5vsb and it is shorted but de real failure iselsewere.
Reply 17 of 27, by dfaber1
91.29 KiB
I removed the Gigabyte IC and the short is gone. I will order a new one and hopefully the board will come back to life.
