First post, by TrashPanda
Is there a fast way to tell FPM sticks from EDO sticks ?
I have a pile of 72 pin sticks and need an easy method to tell the FPM modules from the EDO modules, some of them are marked with stickers but quite a few of them have no identifying markings. I do have a 486 motherboard that can accept either but not both types at once and well this is an issue, is it possible to identify the type by markings on the ICs ?
Any help here would be appreciated.
Edit - is there a memory tester that can do this ?
