Identifying Memory
First post, by TrashPanda
Is there a fast way to tell FPM sticks from EDO sticks ?
I have a pile of 72 pin sticks and need an easy method to tell the FPM modules from the EDO modules, some of them are marked with stickers but quite a few of them have no identifying markings. I do have a 486 motherboard that can accept either but not both types at once and well this is an issue, is it possible to identify the type by markings on the ICs ?
Any help here would be appreciated.
Edit - is there a memory tester that can do this ?
Reply 1 of 9, by red-ray
The chipset usually reports if the SIMMs are FPM or EDO so just check what the chipset reports
file.php?id=155484
Reply 2 of 9, by TrashPanda
Thats certainly an option, is there a DOS version of this SIV32 ?
The 486 doesn't have windows currently installed.
Reply 3 of 9, by red-ray
TrashPanda wrote on 2023-01-20, 11:46:
Is there a DOS version of this SIV32 ?
No and it won't run on WFW 3.11 either. You would need the original W95 build 950 or later or Windows NT 3.51 or later. Further SIV should need to support whatever chipset the 486 MB has.
Reply 4 of 9, by TrashPanda
red-ray wrote on 2023-01-20, 12:02:
If there is no other way to identify them then Ill have to pull out one of the i430 boards I have and setup Win95 on it.
Reply 5 of 9, by weedeewee
read the chip markings and look up the datasheet.
which ofcourse only works if you can find a datasheet.
Do not ask Why !
Reply 6 of 9, by TrashPanda
weedeewee wrote on 2023-01-20, 12:42:
Yes ..very true, Ill give that a shot might find sheets for the better known ones which will thin the pile out.
Reply 9 of 9, by SDumas
Hi !,
I use this board (Terminator SMT486) that tells me the capacity and type of the simm when i dont have
the datasheet of the chips.
This board has the advantage of working only with 1 simm.
