shevalier wrote on 2023-08-13, 17:54:
To be honest, it looks like a desire to replace some 20-year-old capacitors of unknown condition with other 20-year-old ones.
Was about to post the same. Those MBZs are capacitors from the late 2000s. At best. Even if those caps are unused, they most likely are already degraded badly.
I don't understand why OP wants to do this, because datasheets are available for the originals and he could just find matching ones looking at the capacitance and voltage values, ripple current and ESR and order new matching capacitors. If similar caps aren't available anymore, then polymers should do the trick. Polymers of course change the look somewhat, but I'd choose changed look over the other option which is having an unreliable or non-working MB.
