First post, by Zerthimon
I have a motherboard with 3 VRMs with total of 20 nichicons 1500uF/6.3V, some of which are bulged. I would like to replace all of those nichicons with rubies 3300uF/6.3V (I ony got these in stock, currently). Will this work or is it a bad idea?
Reply 1 of 21, by Tiido
You probably want to keep things the way they are, it is quite likely all that extra capacitance will appear as a big enough short on startup that the VRM enters and stays in protection.
Reply 2 of 21, by weedeewee
if the capacitors are in parallel then you can replace two 1500 with one 3300
Do not ask Why !
Reply 3 of 21, by Zerthimon
Tiido wrote on 2023-08-11, 21:24:
Yeah, I also thought that all that extra capacitance may overload the VRM. 🙁
Reply 4 of 21, by Zerthimon
weedeewee wrote on 2023-08-11, 21:32:
True, the caps are in parallel but I'd like not to change the mobo appearance.
So I guess, I'll be looking for 20 caps of 1500uF of the same size. The problem is that I rarely see such caps on a donor boards. 🙁
Reply 5 of 21, by Tiido
You can use half as many, although ESR and ESL are improved with more smaller parts compared to less and larger ones. The machine is unlikely to have any problem with half as many 3300µF ones vs all 1500µF ones.
Reply 6 of 21, by majestyk
If the 3300µF/16V caps really do fit in the places of the original 1500µF / 6.3V types, the 3300µF caps are either of poor quality or/and have too high ESR.
Can you provide the manuf. / series or a picture?
Reply 7 of 21, by shevalier
By and large, it is not the capacitance that matters, but the allowed current through the capacitors. Well, the ESR, as without it.
If the 3300 uF capacitor has a ESR and the allowable current is two times better than that of 1500, then you can set 1 instead of 2.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 8 of 21, by shevalier
Zerthimon wrote on 2023-08-11, 21:51:
So use the right donor.
    835.06 KiB
Reply 9 of 21, by analog_programmer
What "appearance"? Even the manufacturers like Gigabyte used this "trick" to spare some parts from their motherboards 20 years ago. I have one PIII board with half of capacitor's pads on main lines to CPU unpopulated. They're paired in parallel with pads with soldered 3300 mF caps. The manufacturer did the same - used one 3300 uF capacitor instead of two 1500 or 1800 uF.
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 10 of 21, by BitWrangler
majestyk wrote on 2023-08-12, 05:34:
Capacitors were somewhat bulkier in late 20th century and shrank a bit at the beginning of this one.
Reply 11 of 21, by majestyk
BitWrangler wrote on 2023-08-12, 12:03:
It depends, physics still apply. A good low ESR capacitor for higher ripple current 3300µF 16 V still measures 16mm x 22mm:
https://www.digikey.com/en/products/detail/ru … wWUQA0xsQBdAXyA
I doubt the original 1500µF 6.3V were that large...
There exist - of courrse - far smaller ones with 3300µF / 16V, but they fail regarding lifetime and/or ESR and/or ripple current.
Reply 12 of 21, by analog_programmer
majestyk wrote on 2023-08-12, 19:49:
It depends, physics still apply. A good low ESR capacitor for higher ripple current 3300µF 16 V still measures 16mm x 22mm: htt […]
There is no strict standard dimensions for capacitors with equal capacitance rated for same voltage. Even today some caps are "wider", others are "thinner" or "shorter"/"longer". Also dimensions varies between manufacturers/vendors. And as it was already mentioned even electrolytic caps "evolve" and somehow become "smaller" (especially those from respected brands).
Reply 13 of 21, by Zerthimon
I wanted to replace these
1.35 MiB
with these
1.42 MiB
Edit: the rubies are 6.3V, updated the OP.
Reply 14 of 21, by weedeewee
possibly applicable datasheets ?
    e-hd.pdf
    902.11 KiB
    34 downloads
    nichicon HD series capacitors
    MBZ.pdf
    99.54 KiB
    34 downloads
    rubycon MBZ series capacitors
Do not ask Why !
Reply 15 of 21, by disaster
I don't get the source of the problem.
Just buy some low esr caps with correct capacity and voltage.
1500uF/6,3V caps are so ridiculously cheep that using some used but higher capacity ones is pure madness 😀
Reply 16 of 21, by shevalier
Zerthimon wrote on 2023-08-13, 12:04:
with these
To be honest, it looks like a desire to replace some 20-year-old capacitors of unknown condition with other 20-year-old ones.
Reply 17 of 21, by CharlieFoxtrot
shevalier wrote on 2023-08-13, 17:54:
Was about to post the same. Those MBZs are capacitors from the late 2000s. At best. Even if those caps are unused, they most likely are already degraded badly.
I don't understand why OP wants to do this, because datasheets are available for the originals and he could just find matching ones looking at the capacitance and voltage values, ripple current and ESR and order new matching capacitors. If similar caps aren't available anymore, then polymers should do the trick. Polymers of course change the look somewhat, but I'd choose changed look over the other option which is having an unreliable or non-working MB.
