First post, by andy120
I have acquired a km400a mb that does not power on. however if i force power i get a repeating 2 tone, higher and lower pitch. never come across that before. any idea what it means. happens with and without ram and cpu fan.
Powered by one Harris 286-12
Reply 4 of 5, by Repo Man11
In such a situation, one of the best ways to eliminate the possibility of an unintentional ground is to remove the motherboard from the case and set it up on a bench with the bare minimum of components and test it that way.
