bios error code
First post, by andy120
I have acquired a km400a mb that does not power on. however if i force power i get a repeating 2 tone, higher and lower pitch. never come across that before. any idea what it means. happens with and without ram and cpu fan.
Powered by one Harris 286-12
Reply 1 of 5, by giantclam
if Ami BIOS that's low cpu fan speed
Reply 2 of 5, by andy120
yes its ami. will try a different fan. caps all look good and no burn marks.
Reply 3 of 5, by andy120
The fans do a twitch only on both cpu and chassis.
Reply 4 of 5, by Repo Man11
In such a situation, one of the best ways to eliminate the possibility of an unintentional ground is to remove the motherboard from the case and set it up on a bench with the bare minimum of components and test it that way.
Reply 5 of 5, by giantclam
If the +12v rail is good then it must be failing post and shutting down ~ caps "looking good" means nothing really ...what do you mean by 'forcing power"?
+1 on repo man's advice
