First post, by mrfusion92
Slot-1 mATX motherboards with AGP are somewhat pricey. I can't find anything for less than 100€ which is way too much.
Are there perhaps less know models which may go at lower prices? I'm fine even with OEM motherboards.
Reply 1 of 16, by dominusprog
Well, it depends entirely on the seller. Here, take a look at this
https://www.ebay.com/itm/266456785581?hash=it … ABk9SR_b6lNjnYg
Reply 4 of 16, by dionb
What are your other requirements other than uATX, Slot 1 and AGP?
Do you need:
- ISA?
- 100 or 133MHz FSB support?
- Coppermine/Tualatin voltage support?
- Certain max supported memory?
- Universal AGP 2.0 4x?
- Compatible with SBLive?
etc
In general 1997-1999 OEM boards are most likely to have Slot 1 in that form factor, but that means you have chipsets that frequently will only support pre-Coppermine (or ever pre-Deschutes) Slot 1 CPUs, 66MHz FSB, AGP 1.0 (think: FIC VL-603, Gigabyte GA-6EM). Conversely there exist boards with 133MHz FSB but these are rare as hens teeth, they might not have ISA slots and there's a good chance they have a Via 686B southbridge that doesn't play nice with an SBLive (think: AOpen MX64)
Reply 5 of 16, by mrfusion92
Babasha wrote on 2023-10-17, 13:03:
Something like this? 😉
Yeah, is it an OEM? Can't understand model name.
dionb wrote on 2023-10-17, 13:28:
What are your other requirements other than uATX, Slot 1 and AGP? […]
Do you need:
- ISA?
etc
The CPU will be a PII Deschutes @350Mhz, so 100Mhz FSB. Don't need Coppermine support since I already have two socket 370 systems (a Coppermine and a Tualatin). GPU will be a Matrox G200.
I haven't decided the sound card yet so maybe an ISA slot would be nice to have in case. But it's not essential.
Reply 6 of 16, by zyga64
If G200 can be integrated on board (so no AGP slot) there is currently HP D7600-60004 (SHERWOOD-B) SLOT1 motherboard on polish auction site allegro.pl (about 25€).
1) VLSI SCAMP /286@20 /4MB /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16MB /TGUI9440 /YMF718+GUS
3) i430FX /K6-2@400 /64MB /Rage Pro PCI /ES1370+ALS100
4) i440BX /P!!!750 /256MB /MX440 /SBLive!+Vibra16s
5) iB75 /3470s /4GB /HD7750 /HDA
Reply 7 of 16, by Babasha
mrfusion92 wrote on 2023-10-17, 14:10:
Yeah, is it an OEM? Can't understand model name. […]
Do you need:
- ISA?
etc
Its a Siemens D1115 motherboard. PM?
Need help? Begin with photo and model of your hardware 😉
Reply 8 of 16, by mrfusion92
I wanted a mATX because I already had only a mATX case available but yesterday just before closing time a PC arrived in my office to be scrapped... and it's a nice black full ATX case with an IDE DVD-ROM and floppy, both with black faces.
Of course now that case is safe at my home!
Reply 10 of 16, by ChrisK
I recently acquired a Biostar M6VBE for a low price (not from ..bay). But I don't know common market prices for that.
A MSI MS-6156 should also be a good fit (available with Intel BX chipset but also as a Via Apollo Pro 133 variant, the latter being more common as it seems). Have seen these relatively often for well below 100 EUROs in recent times, mostly in combination with a P III 500-650MHz.
Edit: both are µATX, have AGP, 3 PCI, one ISA and ESS Solo1 / Creative ES1373 soundchips onboard.
Reply 11 of 16, by stef80
Chaintech had few mATX slot-1 boards with Intel 440, VIA Apollo and SiS chipsets. All with various integrated sound chips: ESS Solo-1, ESS Maestro-2, Yamaha.
* Chaintech CT-6BSA - Intel 440BX + ESS Maestro-2
* Chaintech CT-6BSV - Intel 440BX + ESS Maestro-2 + Ati Rage Pro / no AGP
* Chaintech CT-6ESA2 - Intel 440EX + ESS Solo-1
* Chaintech CT-6ESV - Intel 440EX + ESS Solo-1 + ATI Rage Pro / no AGP
* Chaintech CT-6SSA2 - SiS 5600 + ESS Solo-1
* Chaintech CT-6ASA - VIA Apollo Pro II+ ESS Maestro-2
(not a complete list)
Reply 12 of 16, by Nexxen
stef80 wrote on 2023-10-18, 09:58:
Chaintech had few mATX slot-1 boards with Intel 440, VIA Apollo and SiS chipsets. All with various integrated sound chips: ESS S […]
Are these any real good? Or just low quality but available? To understand.
I was offered a few and can't really get around the idea of buying. They are: CT-6ATA2, BTA2 and BTML.
Ok, if someone wants to use a slot board but is it worth it with these brands?
That's preventing me from buying. Not that I need them as I have a few too many...
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 13 of 16, by stef80
Have a SiS one from the list, looks decent. Tested with P2-300@450, but haven't build anything around it. Reason being, I got Chaintech CT-5RSA2 which is a more interesting mATX board for a build.
Reply 14 of 16, by zyga64
I don't recommend SIS based Slot1 motherboards due to poor memory performance
Intel > VIA > Ali ~= Sis
Reply 15 of 16, by PARKE
Nexxen wrote on 2023-10-18, 11:59:
Are these any real good? Or just low quality but available? To understand. I was offered a few and can't really get around the i […]
There is in general nothing wrong with Chaintech motherboards as a brand but the CT-6ATA2 that you mention is based on the Apollo Pro133 chipset and the one that I once owned was annoyingly slow = read much slower than 440BX.
Reply 16 of 16, by mrfusion92
I will look into every option, the Chaintech models with integrated sound card seem a good idea. I'm not interested in 100% DOS compatibility, I do have other dedicated systems for that.
