First post, by mrfusion92
Slot-1 mATX motherboards with AGP are somewhat pricey. I can't find anything for less than 100€ which is way too much.
Are there perhaps less know models which may go at lower prices? I'm fine even with OEM motherboards.
Reply 1 of 18, by dominusprog
Well, it depends entirely on the seller. Here, take a look at this
https://www.ebay.com/itm/266456785581?hash=it … ABk9SR_b6lNjnYg
Reply 2 of 18, by mrfusion92
I have to double check but I'm pretty sure that in the matx case that I'll use a baby AT motherboard won't fit because there is an HDD cage.
Reply 3 of 18, by Babasha
Something like this? 😉
Need help? Begin with photo and model of your hardware 😉
Reply 4 of 18, by dionb
What are your other requirements other than uATX, Slot 1 and AGP?
Do you need:
- ISA?
- 100 or 133MHz FSB support?
- Coppermine/Tualatin voltage support?
- Certain max supported memory?
- Universal AGP 2.0 4x?
- Compatible with SBLive?
etc
In general 1997-1999 OEM boards are most likely to have Slot 1 in that form factor, but that means you have chipsets that frequently will only support pre-Coppermine (or ever pre-Deschutes) Slot 1 CPUs, 66MHz FSB, AGP 1.0 (think: FIC VL-603, Gigabyte GA-6EM). Conversely there exist boards with 133MHz FSB but these are rare as hens teeth, they might not have ISA slots and there's a good chance they have a Via 686B southbridge that doesn't play nice with an SBLive (think: AOpen MX64)
Reply 5 of 18, by mrfusion92
Babasha wrote on 2023-10-17, 13:03:
Yeah, is it an OEM? Can't understand model name.
dionb wrote on 2023-10-17, 13:28:
What are your other requirements other than uATX, Slot 1 and AGP? […]
Do you need:
- ISA?
etc
The CPU will be a PII Deschutes @350Mhz, so 100Mhz FSB. Don't need Coppermine support since I already have two socket 370 systems (a Coppermine and a Tualatin). GPU will be a Matrox G200.
I haven't decided the sound card yet so maybe an ISA slot would be nice to have in case. But it's not essential.
Reply 6 of 18, by zyga64
If G200 can be integrated on board (so no AGP slot) there is currently HP D7600-60004 (SHERWOOD-B) SLOT1 motherboard on polish auction site allegro.pl (about 25€).
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 7 of 18, by Babasha
mrfusion92 wrote on 2023-10-17, 14:10:
Yeah, is it an OEM? Can't understand model name. […]
Do you need:
- ISA?
etc
Its a Siemens D1115 motherboard. PM?
Reply 8 of 18, by mrfusion92
I wanted a mATX because I already had only a mATX case available but yesterday just before closing time a PC arrived in my office to be scrapped... and it's a nice black full ATX case with an IDE DVD-ROM and floppy, both with black faces.
Of course now that case is safe at my home!
Reply 9 of 18, by dionb
That broadens your options significantly, and with a P2 Deschutes, any i440BX board would be a perfect match.
Reply 10 of 18, by ChrisK
I recently acquired a Biostar M6VBE for a low price (not from ..bay). But I don't know common market prices for that.
A MSI MS-6156 should also be a good fit (available with Intel BX chipset but also as a Via Apollo Pro 133 variant, the latter being more common as it seems). Have seen these relatively often for well below 100 EUROs in recent times, mostly in combination with a P III 500-650MHz.
Edit: both are µATX, have AGP, 3 PCI, one ISA and ESS Solo1 / Creative ES1373 soundchips onboard.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 11 of 18, by stef80
Chaintech had few mATX slot-1 boards with Intel 440, VIA Apollo and SiS chipsets. All with various integrated sound chips: ESS Solo-1, ESS Maestro-2, Yamaha.
* Chaintech CT-6BSA - Intel 440BX + ESS Maestro-2
* Chaintech CT-6BSV - Intel 440BX + ESS Maestro-2 + Ati Rage Pro / no AGP
* Chaintech CT-6ESA2 - Intel 440EX + ESS Solo-1
* Chaintech CT-6ESV - Intel 440EX + ESS Solo-1 + ATI Rage Pro / no AGP
* Chaintech CT-6SSA2 - SiS 5600 + ESS Solo-1
* Chaintech CT-6ASA - VIA Apollo Pro II+ ESS Maestro-2
(not a complete list)
Reply 12 of 18, by Nexxen
stef80 wrote on 2023-10-18, 09:58:
Chaintech had few mATX slot-1 boards with Intel 440, VIA Apollo and SiS chipsets. All with various integrated sound chips: ESS S […]
Are these any real good? Or just low quality but available? To understand.
I was offered a few and can't really get around the idea of buying. They are: CT-6ATA2, BTA2 and BTML.
Ok, if someone wants to use a slot board but is it worth it with these brands?
That's preventing me from buying. Not that I need them as I have a few too many...
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 13 of 18, by stef80
Have a SiS one from the list, looks decent. Tested with P2-300@450, but haven't build anything around it. Reason being, I got Chaintech CT-5RSA2 which is a more interesting mATX board for a build.
Reply 14 of 18, by zyga64
I don't recommend SIS based Slot1 motherboards due to poor memory performance
Intel > VIA > Ali ~= Sis
Reply 15 of 18, by PARKE
Nexxen wrote on 2023-10-18, 11:59:
Are these any real good? Or just low quality but available? To understand. I was offered a few and can't really get around the i […]
There is in general nothing wrong with Chaintech motherboards as a brand but the CT-6ATA2 that you mention is based on the Apollo Pro133 chipset and the one that I once owned was annoyingly slow = read much slower than 440BX.
Reply 16 of 18, by mrfusion92
I will look into every option, the Chaintech models with integrated sound card seem a good idea. I'm not interested in 100% DOS compatibility, I do have other dedicated systems for that.
Reply 17 of 18, by wadstroem
Bumping this thread cause I'm looking for exactly this kind of choice for my 9x build. PM?
Reply 18 of 18, by ubiq
I've got an ASUS P3B-1394 which I've found to be a pretty good Slot 1 mATX. The onboard firewire for which it is named isn't too useful, but the onboard Aureal Vortex 2 sound certainly is! It's a proper 440BX with 100MHz FSB support. It even has a fairly "modern" ATX power connector placement. Only real complaint with the board is that it has non-reconfigurable IRQs shared with certain PCI slots, which can complicate resource management with add-on cards.
