First post, by zuldan
- Member
Apologies for this silly question, just want to double check before I order the wrong thing.
I have an old PC case from 1998 that has screw holes for fans that are 70mm apart. Can you assume a 80mm fan has 70mm screw holes?
I'm assuming the measurements are like the following?
