First post, by Aui
Hi everyone, Im currently looking at an old Dell machine (433/L) and found an old barrel battery mantled with tape. Opening the tape revealed a stack of 3 GPA76 (LR44) coin cells. Is this the "original solution" Dell came up with? Im wondering because the connector on the board was corroded and turned green on an otherwise good looking board. What would be the best replacement ? Just get another stack of LR41? Or is there an alternative solution?
Thanks
