First post, by caver99
does any one know of an equivalent part to nec d481850gf
Is that the uPD481850? I've attached the pinout pages from the datasheet, which was in the 1996 NEC databook on bitsavers.org
If so, it's an 8Mb SGRAM, arranged as 128k addresses, 32 bits wide, in 2 banks, in a 100 pin QFP package. I haven't had a close look at other datasheets, but it looks like there might be compatible parts, e.g. http://dosdays.co.uk/media/fujitsu/MB81G83222_Datasheet.pdf . But I've only done a 30sec check on some of the pinout, so I don't know if it's really compatible.
snufkin wrote on 2024-04-05, 18:38:Is that the uPD481850? I've attached the pinout pages from the datasheet, which was in the 1996 NEC databook on bitsavers.org
It surely is. It is very common for NEC chips to omit the µP prefix on the chip marking.
so the uPD481850 will fit in place of d481850gf and do the same job?
