Reply 80 of 153, by gerwin
- l33t
There is some new development activity around the Dune Dynasty project, here:
https://github.com/1oom-fork/dunedynasty
Yeah, 1oom, the Master of Orion 1 project, is there too.
There are no new binaries available AFAIK, just source code.
Suspect the original Dune Dynasty developer Mr. Wang has the github account "wangds". But that is not the account making the recent changes.
From current changes.txt:
Version 1.6.3, 2022-04-28 ------------------------- - New Action Panel mode: Interactive unit list - Shift + click removes […]
- Shift + click removes clicked unit from list
- Shift + Ctrl + click removes clicked unit type from list
- Ctrl + click removes all units except clicked type
- Click removes all units except clicked unit
- New hotkey: select next building of the same type (Tab key)
- New hotkey: focus viewport on selected structure (Space key)
- Draw health bars for all visible units in "All units" mode
- Fix save/load bug: fix fog data loss in saved games
- Fix pathfinder freeze in case if destination is out of mapVersion 1.6.2, 2022-04-14
-------------------------- Action Panel title text no longer reacts to mouse clicks
- Action Panel title click behavior moved to the portrait
- Add old style status button to action panel
- Remove Send Order button from Starport menu (uses status button)
- Add new status button for Palace menu
- Pause/Cancel factory task by pressing ESC
- Pause/Cancel factory task by rmb click on status buttonVersion 1.6.1, 2022-04-07
-------------------------- Fix critical saveload bug which breaks the behavior of starports
- Fix attempts to spawn Fremen outside the map
- Unbind hotkey H
- Add hotkeys for each type of unit/structure
- Bind unit/structure hotkeys to action panel
- Add hotkey hints to action panelVersion 1.6.0, 2015-02-03
-------------------------- Version changed to 1.6.0 to reflect all those undocumented changes
that were added for 2013-2015Version 1.5.7, 2013-08-18
-------------------------- Fix crash on startup when by using Spanish data files.
- Put nouns before adjectives for Italian and Spanish.
- Use English audio for Italian and Spanish.
