Why doesn't this exist?
First post, by Oldskoolmaniac
So I got to thinking of gadget that should exist that doesn't at all to my knowledge.
You know how the older via chipsets had problems with drives over sata150, yea at lot of the western digital drives have jumpers or you could use a worn down sata1 drive, but it would be really cool if there was a little chip that plugs into the drive and then the sata connector to make it sata1 compliant so any drive can be used like SSD's and it would basically look like those sata to ide converters.
Anyone else got idea on what computer related items that should exist that could be convenient for you?
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 1 of 32, by Neco
System Boards that plug in to PCI Express and contain a complete 486/Pentium class machine with BIOS/RAM etc, that can be run through a software portal on the host system.
It's basically DOSBox but better 😎 (not sure how to handle things like a soundcard tho, maybe slap some chips on there too, like OPL, etc)
Reply 2 of 32, by keenmaster486
At that point it might as well be a single board computer (hint, hint 🙄 )
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Reply 4 of 32, by PhilsComputerLab
Rank Hardware Mod
Hardware Mod
Yea that SATA issue with VIA is a real pain 🤣
My dream gadget is a CD/DVD drive emulator, like a GOTEK.
Connect to IDE, takes a 2.5" SATA drive, little LCD display at the front displaying the ISO / BIN-CUE image and some buttons to cycle through the images.
YouTube, Facebook, Website
Reply 5 of 32, by darry
If I recall correctly (I use them for long term backup), my 3 year old Nexstar 3.5-inch E-SATA/USB 2.0 enclosures actually force a SATA 1 (150) link even when used on with aSATA 2 or 3 capable host and controller.
Apparently, according to reviews, this StarTech enclosure has the same "issue" :
https://www.amazon.co.uk/StarTech-2-5in-Black … e/dp/B002NY9K1Q
E-SATA to SATA capables being cheap and plentiful (I have used some successfully on a few occasions, but never tried one on any Via SATA controller), it would be worth trying one of these enclosures on an affected via controller .
My guess as to why this happens is that a SATA to SATA bridge is used internally when in E-SATA mode is used and that this bridge is limited SATA 1 .
Another thing to try would be to cascade a SATA to IDE (ATA) converter and an IDE (ATA) to SATA converter between the drive and controller, since such converters are, AFAIK, limited to SATA 1 anyway .
Reply 6 of 32, by Oldskoolmaniac
That would be cool for a start-up disk like 98, 2000, xp or linux, but for anything else you would just use software to emulate a virtual drive.
Reply 7 of 32, by jade_angel
It does have advantages like being able to use a large drive to store a bunch more images on machines that can't accommodate modern large disks, and it also works under DOS, OS/2, SCO Unix and other such systems that don't explicitly support mounting of ISO images or have 3rd party software available to do that. It could, in theory, also do various sorts of format translations to let older OSes work with DVD/BluRay data images, translate newer ISO9660 variants into older ones, etc, depending on what the firmware is coded to do. You could also have a multi-interface CD emulator: ATA, SCSI, Wide SCSI, USB, Firewire, as desired.
Also, it means you don't have to manually fart around with mounting images every time you want to play a game that insists on having the CD inserted.
I'd pay decent money for such a device, to be sure.
Main Box: Ryzen-TR 1900X | GTX 1050/Radeon RX 580
98/2000 Box: PIII/766 |Quadro4 380 XGL
Reply 8 of 32, by Oldskoolmaniac
^^^True, I forgot about DOS.
Reply 9 of 32, by DosFreak
Think the best you're going to get right now for a system that doesn't support USB boot would be Plop boot manager with the Zalman ZM-VE external enclosure.
https://www.plop.at/en/bootmanager/rom.html
https://www.plop.at/en/plopkexec/full.html
http://www.zalman.com/contents/products/view.html?no=212
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 10 of 32, by Rhuwyn
Neco wrote:
System Boards that plug in to PCI Express and contain a complete 486/Pentium class machine with BIOS/RAM etc, that can be run […]
There did used to be old Macs that you could buy an expansion card which had basically a full 486 system on the card but it could share memory with the host system and run off HD images on the local drive. It was really cool but with emulation where it's at most companies aren't going to see any profit in doing anything similar today.
Reply 11 of 32, by Tetrium
A 486 ATX board with AGP slot that's electronically a PCI slot.
This is actually a fantastic idea! 😁
Would also be helpful for stuff like testing msbatch-ed and NLited install media on real hardware!
My retro rigs (old topic)
Report spammers here!
Reply 12 of 32, by jade_angel
There was even one called SunPCi for Sun workstations. The latest version had an Athlon CPU and I think the same ATI graphics chip that Sun was putting on their workstations at the time (Radeon 7500, IIRC).
The advantage such a thing would have over emulation is basically being bug-for-bug compatible with the real hardware, but I doubt there'd be a lot of commercial interest in that unless non-AMD64 workstations were to suddenly come back into vogue. ARMs, I suppose, might create such a niche: emulating x86/AMD64 on an ARM is not exactly a zoomy experience, so one might be better off with a real-deal Atom or notebook Core chip on a card.
Reply 13 of 32, by nforce4max
That would certainly be a space saver big time, swapping disks bleh 😵
Reply 15 of 32, by PhilsComputerLab
Rank Hardware Mod
Hardware Mod
havli wrote:
NAS and some kind of a virtual CD/DVD drive works just fine... no need for such thing. 😊
That works great for Windows 98, but not so much in DOS.
Reply 16 of 32, by M-HT
Plus an analog audio out for audio tracks.
Reply 17 of 32, by Kreshna Aryaguna Nurzaman
A modern PCIe motherboard with ISA slots and Windows 9x support.
A modern video card (Radeon, GeForce, whatever) which provides full 3dfx backward compatibility. Ie you can boot in pure DOS, then run DOS GLide games on it, and the games would recognize the card as Voodoo1 card --only faster and you can maximize FSAA with it (special environment variables, whatever).
Kreshna Aryaguna Nurzaman.
Reply 18 of 32, by Stiletto
We have a thread about this somewhere.
Enclosures with this feature already somewhat exist and work alright in Windows.
do the Fandango!" - Queen
Stiletto
Reply 19 of 32, by Stiletto
There's a thread like this somewhere too, perhaps in Marvin, so if it gets found don't get offended if this gets merged later. 😀
Stiletto
