The Problem with Microsoft tablet is it’s Graphical user interface ( GUI ).
It’s just cumbersome and Awkward to use compared to the iPad.
You really need to use a stylus in order to use the Microsoft tablet. It just isn’t designed to be used with your fingers.
The iPad is inexpensive. You cant build a computer with the same specs of the iPad for less.
The iPad has a high end Retina display and a built in UPS ( Battery ).
Auto backup of all your stuff to the Cloud and integrates perfectly with other Apple devices.
It’s the entire easy of integration between Apple devices that makes it so desirable.
I think the iPad is the Best computer Apple makes for too many reasons and it is Apples least expensive computer.
It’s the perfect size for a mobile computer at 9.7 inches.
It would help if it was a little lighter in weight.
