First post, by egrabczewski
I'm trying out a "new" (eBay purchased) Yamaha Audician 32 Plus card with SoftMPU but I've had no luck with getting MIDI output into my Roland MT-32 (using the usual MIDI/JOYSTICK port and cable).
Previously I'd successfully used a Sound Blaster 16 Value (CT-4170) with the following command line:
SOFTMPU /MPU:3300 /SB:220 /IRQ:5 /DELAYSYSEX /OUTPUT:SBMIDI
My PC hangs if I use the same line above on the Yamaha card. It doesn't like the /OUTPUT:SBMIDI argument. I'm told I shouldn't use it anyway.
Does anyone have any ideas where I'm going wrong. Of course the card might be faulty on MIDI (I've heard some very faint audio in MS-DOS 6.21 but that's all).
On booting the PC I get the following display of system settings for the card:
ISA/PNP Device listing ...
Card No. Device No. DMA IRQ Device Name
1 0 0,1 5 OPL3-SA3 Sound Board
1 1 0,0 NA OPL3-SA3 Sound Board
(sorry if the previous table get's mashed by the forum software)
Reply 1 of 2, by egrabczewski
I never managed to get the Audician 32 Plus to work in the end. Had to swap it out.
Also, the /OUTPUT:SBMIDI flag wasn't necessary for the Sound Blaster 16 WavEffects (not Value); it worked fine without it.
Reply 2 of 2, by MKT_Gundam
egrabczewski wrote on 2019-12-18, 07:27:
I'm trying out a "new" (eBay purchased) Yamaha Audician 32 Plus card with SoftMPU but I've had no luck with getting MIDI output […]
Are you using win 95/98?
Use the driver from Phils site. watch the video to see how setup the irq for DOS mode.
https://www.youtube.com/watch?v=2_L_1tvH1Ew
