Games that work in VR (3D) with DGVoodoo2
Reply 60 of 92, by RJ8
-Dungeon Keeper 2 - DGVoodoo2 2.6 required 3D through Z-Buffer access, important that you read the vorpx profile footnotes
Request a game profile for VorpX - VorpX Inofficial Gamelist - RJs VorpX Games
Reply 61 of 92, by RJ8
-Soul Reaver 1 and Soul Reaver 2 - DGVoodoo2 2.6 (DX6/8) required The first game has Z3D, the second Z3D and G3D.
Reply 62 of 92, by RJ8
-Rainbow Six - DGVoodoo2 2.6
Reply 67 of 92, by RJ8
-Tomb Raider 2 - Z3D , z-buffer must be enables in the games settings (requires DGVoodoo2 2.6 )
Note: If you manage to get Z-Buffer enabled in Tomb Raider 4+5 you may use the same profile for Z3D.
There is also an alternate OpenGL way to play the game in G3D with an older OpenGl profile, read more here
Reply 68 of 92, by RJ8
-Tomb Raider 3 - Z3D , z-buffer must be enables in the games settings (requires DGVoodoo2 2.6 )
Reply 69 of 92, by RJ8
-Alice in Wonderland - G3D , (requires DGVoodoo2 2.6 - DX9 )
Reply 71 of 92, by RJ8
-Kaan: Barbarian’s Blade - G3D -requires DGVoodoo2 2.6
Reply 76 of 92, by syhlif32
Could be the whole thing just gets very unstable and for what ever reason the Cliff House always starts with 2.7 and VorpX .
So it is likely a WMR issue
Will experimenting some more!
And anyway I am and should be very happy with how well it all runs on the monitor !
Reply 77 of 92, by RJ8
I do not re-check every game after a DGVoodoo or VorpX Update. Some games may not work anymore after an update , please simply try older or newer DGVoodoo versions in the case.
The version numbers above indicate the version that i have tested my vorpx profile with. Unfortunately vorpx cant officially be rolled back, so it wouldnt make sense to also
mention the vorpX version a profile has been made with. Note: DGVoodoo2 is not officially supported by vorpX, its an experimental feature and if a game will work or not
is unpredictable.
