First post, by koleq
I will soon upgrade the memory to 96 MB's and a Sound Blaster Live 5.1 (if it's gonna work).
So, what games should I definitively try?
DOS/Windows games all welcome, but no emulators, I can emulate on a stronger machine.
The more games the better, and I would like to see some 3D games even tho I do not have a 3D accelerator.
###HP Vectra VL 5/133 Series 4, D4644B###
CPU: Pentium 1 133Mhz
RAM: 96 MB EDO RAM (4x8MB, 2x32MB)
GPU: ELSA Victory 3DX (S3 Virge/DX 4MB)
Sound: Avance Logic ALS100 Plus+ REV 2.0
HDD: Seagate 20 GB (need to boot OnTrack)
OS: Windows 98 SE
Reply 1 of 37, by Con 2 botones
To name a few must play:
2D: Command and Conquer Red Alert, Oddworld: Abe's Oddysee, Age of Empires (1), Diablo (1), Blade Runner, Baldur´s Gate
3D: Turok, POD, Tomb Raider, Colin McRae Rally (1), Motoracer, Duke Nukem 3D, Quake, Blood, Croc, MDK, Need for the Speed II
I read you don´t own a 3D accelerator yet. Prices are high for period correct PCI 3D accelerator cards. Maybe you could get a Rage 3D Pro (or its a newer variant, the Rage XL) which is still affordable. It will let you play all of the above mentioned decently.
In the meantime, your system will handle all the DOS era classics just fine.
Reply 2 of 37, by koleq
Con 2 botones wrote on 2022-04-05, 12:32:
I have a problem and that is my pc only has 2 PCI slots and I have an ethernet card and sound blaster live 5.1 in them already so I don't even have slot for a 3D card.
I should get an ISA soundcard but it's difficult to find a "good" one at a reasonable price.
OS: Windows 98 SE
Reply 3 of 37, by thepirategamerboy12
I don't believe Yamaha Audician 32 based cards are too expensive at the moment.
Reply 4 of 37, by chiveicrook
Over the mountains to the north (if I guessed your location right) you can buy the following for reasonable prices:
ESS cards, especially those with ES1868F, tend to sell for under 15 EUR. I think they offer great bang for the buck.
Crystal cards often sell for as little as 5EUR.
Opti, ALS, Analog Devices and CMI8330 stuff starts around 10EUR.
SB Vibras start around 20EUR, but for 20EUR you can choose almost everything.
Reply 5 of 37, by Cuttoon
To name a few must play: 2D: Command and Conquer Red Alert, Oddworld: Abe's Oddysee, Age of Empires (1), Diablo (1), Blade Runne […]
AFAIK, Duke 3D has no hardware 3d acceleration and should run fine on a p1.
The whole Tie-Fighter and Dark Forces franchise comes to mind for that time.
koleq wrote on 2022-04-05, 13:08:
Depends on how many ISA slots there are, but an ISA ethernet will suffice for most things. 10 Mbps is still much better than none.
Plenty of affordable sound cards around 20 € with AL100, Crystal or ESS chips.
I like jumpers.
Reply 6 of 37, by koleq
Cuttoon wrote on 2022-04-05, 16:49:
I am currently bidding on a Avance Logic ALS100 Plus REV 2.0 with the LS262 OPL3 clone chip.
here is the picture on the listing.
OS: Windows 98 SE
Reply 7 of 37, by devius
Two games that don't get mentioned that often:
- Fire Fight
- Crusader: no Remorse
Reply 8 of 37, by Gmlb256
  • Crusader: No Regret (complementing the above post which is the sequel to No Remorse)
  • StarCraft
  • Stargunner
  • Tyrian
  • WarCraft II
All of the mentioned games aren't 3D rendered but works very well on a Pentium 133.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 9 of 37, by gerry
i used to play carmageddon on a P1 166 , that was a fun game!
Reply 10 of 37, by appiah4
More than 64MB on that mainboard is a bad idea.
Reply 11 of 37, by chuky
Without 3d acceleration, there's Little Big Adventure 1 and 2, Skynet, Total Annihilation, Grand Prix 2.
Games with acceleration that can run without, there's the series of car games Screamer 1, 2 and Rally, Destruction Derby 2.
In 2d Theme Hospital, Fallout 1, Monkey Island 3.
Older Dos games have non accelerated 3d too, Commanche maximum overkill was pretty impressive at the time, Big Red Racing was fun, there's all the sharewares like Doom, Descent, Whacky Wheels, etc.
Reply 12 of 37, by Sphere478
Sim city 2000
Specter challenger
Myst
What mobo is it?
Got a pic?
Ultimate retro link?
I tried looking up the mobo in your signature
I couldn’t find the exact one but I assume it’s similar to one I found where it is a non standard form factor with a riser all the way at the back on one side.
Looks like it has onboard sound and video?
If so, you could probably put up with the onboard sound in favor of a pci gfx. I’d suggest a radeon 7500. I’ve had really good luck with them on my socket 7 builds.
Also I noticed that the board seems to have a spot for a vrm module upgrade. Depending on what voltages that vrm supports it may allow for upgrading to a k6-3+ 400-500mhz
Sphere's PCB projects.
Reply 13 of 37, by koleq
Sphere478 wrote on 2022-04-26, 03:39:
What mobo is it? […]
What mobo is it?
Got a pic?
I actually kinda don't want to make this PC much faster than it is now, I kinda want to live with the limitations the PC gives me.
the PC has 3 ISA slots and 2 PCI slots in a daughter card.
in the PCI slots I have an ethernet card - to access my home NAS
and S3 Virge/DX 4MB 3D accelerator (yeah people don't like the card, but I think it's cool and interesting.)
and in one of the ISA slots, I have a soundcard.
The motherboards has an integreated S3 Trio64 video card, but no integreated sound.
I have tried a bunch of games, most of Windows games run very slowly, and DOS games run great.
Keep the suggestions comming.
OS: Windows 98 SE
Reply 14 of 37, by leileilol
The S3 Trio64 is essentially a 3dless Virge more or less, so you'll not miss out much if you take out the Virge and roll with Trio64+V2.
Reply 15 of 37, by RandomStranger
I share leileilol's opinion. If you sacrifice one of your 2 PCI slots, then you should use a better 3D accelerator that actually accelerates 3D (or at least displays correctly). I also have a soft spot for S3 graphics cards, but their 3D accelerators preceding Savage3D are not good.
Reply 16 of 37, by Gmlb256
I like the S3+ 3Dfx Voodoo accelerator card combo too. 😁
Later ViRGE variants and derivatives has improvements on the 2D core and better RAMDAC. The only variant of the Trio64 that shares some of these improvements is the Trio64V2 (not to be confused with the Trio64V+).
Reply 17 of 37, by Namrok
Hardware aside, here are a few of my favorites I haven't seen anyone pitch in yet.
* Deadlock
* Caesar III
* Warlords III
* Mechwarrior 2
* Master of Orion 2
* Jagged Alliance
* Zork Nemesis & Zork Grand Inquisitor
* Civilization II
* Settlers II
* Might & Magic VI
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 18 of 37, by koleq
I am interested in trying every single Virge game there is, this site has an awesome list of them:
https://ctrl-alt-rees.com/2020-12-06-s3-virge … -downloads.html
OS: Windows 98 SE
Reply 19 of 37, by chuky
The Pentium 133 was around with Windows 95 not 98, you're going to be frustrated with 3d games. The cpu matters a lot for the graphics card to render fast. If you upgrade to a Pentium MMX or K6 around 266 Mhz most games will start getting playable with an S3 Virge (although not as fast as with a 3dfx).
Here are a few other games that should work with your computer.
3d games Banzai Bug, Links LS, Normality inc, Overboard!/Shipwreckers!, Pandemonium, Rally Championship, Sega Rally, Terra Nova Strike Force Centaury, X-wing vs Tie Fighter (I haven't played this one)
2d games 3d Ultra PInball the lost continent, Bad Mojo, Commandos 1 and 2, Heroes of Might and Magic 2, Worms World Party
Kay's Power Goo, a tool to have fun with pictures
