First post, by schoolofmonkey
Hey guys new here.
Been working with PC hardware for 25+ years, decided to go back to my roots for a play.
Now I have 2 systems here, not that old, one is a P4 which is kinda flaky, the other is a Pentium III 550E which from what I can tell works perfectly.
But I seem to be having a problem running only Duke 3D, Blood and Shadow Warrior in dos.
Everything else runs fine, Quake (DOS), GLQuake, Quake III, Unreal, Unreal Tournament, heck even Commander Keen
Specs are:
P3 550Mhz
DFI CA61 Motherboard
512MB Ram (2x 256MB)
Geforce 3 Ti 200
40GB Hard drive partitioned
Soundblaster PCI
Windows 98se.
This is what happens everytime I run anything based on the Duke3D engine, this is even with no sound card selected, 320x200 and straight dos mode:
This does not happen on the P4 at all, but it has a bad cache problem so it randomly boots, hangs or bluescreens, waiting on replacement parts.
Has anyone see this problem before, I've tried with just a single stick of ram, could it be a hardware problem with the P3 too
Thanks.
Reply 1 of 3, by RogueTrip2012
Have you tried the nolfblim patches?
Whats in your autoexec and config files?
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>WXP/W8.1 . AMD 960T . 8GB . GTX285 . SB X-Fi . 128GB SSD
> Win X . i7 4790k . 16GB . GTX1070TI . 256GB SSD
Reply 2 of 3, by schoolofmonkey
Nothing in the Autoexe, just standard HIMEM.SYS and EMM386.EXE in the config, it was the same on the P4, but I never got that crash on the P4, it just worked, same game folder, same video card and sound card used.
The P4 just has other issues running anything too stressful (Like installing Windows XP.. 😒 )
Haven't heard of the nolfblim patch until now, didn't make a difference.
Reply 3 of 3, by Stretch
Setup your PIF shortcut according to the "WINDOWS DOS BOX TIPS" section at WinDOwS Tricks - Part 23
Win11 - AMD Ryzen 9 3900 - 16 GB - GeForce RTX 2060S - Sound BlasterX AE5-Plus
Win98SE - ASRock 775i65G R3.0 - Celeron 2.2 GHz - 2 GB - GeForce FX5700 - Ensoniq 1373
Win98SE - Via Apollo Pro Mobo - Pentium II 233 - 256 MB - Voodoo 3 1000 - ESS Solo-1 1938
