First post, by Lazar81
- Member
Hello,
I was experimenting with standalone DOS 7.1 and unlike DOS 6.22 I have problems with loading all drivers and having enough free conventional memory. I also had freezes depending on the order the drivers are loaded.
At the moment config.sys says that:
device=c:\drivers\xmgr.sys
device=c:\drivers\umbpci\umbpci.sys
files=60
dos=high,umb
devicehigh=c:\drivers\xdvd2.sys /d:DVD
and autoexec.bat says that:
@echo off
prompt $p$g
path c:\dos
set temp=c:\dos
set sound=c:\drivers\sb16
set blaster=a220 i5 d1 h5 p330 t6
set midi=synth:1 map:e
lh keyb gr,,c:\dos\keyboard.sys
lh c:\drivers\usbdos\usbuhci.com
lh c:\drivers\usbdos\usbmouse.com
lh c:\drivers\usbdos\usbkeyb.com
lh c:\drivers\sb16\mixerset /p /q
lh c:\drivers\shsucdx.com /d:DVD
lh c:\drivers\ctmouse.exe /r2
I tried many different orders, a few memory managers... sometimes i have freezes... sometimes it says that there is not enough memory for the drivers loaded later...
And this runs perfectly in DOS 6.22 - i don't understand it.
Ryzen 5 2600X - ASUS ROG STRIX X470-F Gaming - 32GB RAM - Nvidia GeForce GTX 1080 Ti
