First post, by arnovdheiden
Hello,
first of all, thank you all for being a treasure trove of good old retro information. It's great there is an active community for this. If I used the wrong section for this question, sorry for that. Feel free to move this topic to the right one.
I have a pentium 133 system with 64MB ram, and a clean installation of Windows 98 SE NL (Dutch language). What happens is that when i have an open folder, and I have to restart windows after for example a software installation, the folder that was open before the restart, reopens when I enter windows after restart. This is quite annoying behaviour, and it would be great if there is a solution for that.
things I found online like adding a registry entry which adds a folder option to disable this behaviour, did not do anything. So the main and only solution i could find using google, did not work.
I also tried a different ISO of WIN98NL and reinstalled Windows, but that did not change anything.
The weird thing is, is that this problem is already there after a fresh instalaltion, so is it "default" for this windows version? I can't remember this being this way back in 1999.
is there someone that has the same issue and found a good solution?
thank you in advance and best regards,
Arno
Gouda, Netherlands
Reply 1 of 5, by Peter Swinkels
There should be an option accessible from explorer that opens a window where you can set various folder/file related options. One of them is about restoring folders that were open during a shutdown. This window looks something like this: http://www.clubinnovations.com.au/training/te … 98_1/files.html
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 2 of 5, by arnovdheiden
Peter Swinkels wrote on 2022-02-01, 10:02:
There should an option accessible from explorer that opens a window where you can set various folder/file related options. One of them is about restoring folders that were open during a shutdown. This window looks something like this: http://www.clubinnovations.com.au/training/te … 98_1/files.html
Thanks for the suggestion. I read about that, but i don't have that option. I tried to add that option in the registry but it doesn't seem to do anything.
Reply 3 of 5, by Kalle
Yes, it's like that for the whole 9x series, including ME.
From what I could find, MS changed that behavior with IE6. I tried installing IE6 in a VM, and it did disable that behavior of restoring folders on startup. Then also the PersistBrowsers registry entry had an effect and lets you switch that feature on and off as desired.
Reply 4 of 5, by arnovdheiden
Kalle wrote on 2022-02-01, 11:54:
that is a great suggestion. I will try to install IE6 NL and see what happens. Thanks!
