First post, by arnovdheiden
- Newbie
Hello,
first of all, thank you all for being a treasure trove of good old retro information. It's great there is an active community for this. If I used the wrong section for this question, sorry for that. Feel free to move this topic to the right one.
I have a pentium 133 system with 64MB ram, and a clean installation of Windows 98 SE NL (Dutch language). What happens is that when i have an open folder, and I have to restart windows after for example a software installation, the folder that was open before the restart, reopens when I enter windows after restart. This is quite annoying behaviour, and it would be great if there is a solution for that.
things I found online like adding a registry entry which adds a folder option to disable this behaviour, did not do anything. So the main and only solution i could find using google, did not work.
I also tried a different ISO of WIN98NL and reinstalled Windows, but that did not change anything.
The weird thing is, is that this problem is already there after a fresh instalaltion, so is it "default" for this windows version? I can't remember this being this way back in 1999.
is there someone that has the same issue and found a good solution?
thank you in advance and best regards,
Arno
Gouda, Netherlands
