First post, by SteveC
Hi all,
Has anyone ever got a WFW3.11 PC connecting to a modern QNAP NAS? I have SMB v1 enabled on the NAS but it still doesn't want to work.
cheers,
Steve
Reply 1 of 7, by Jo22
Hi. I don't own this NAS - What settings do you use, are both systems in the same WORKGROUP?
It's just a wild guess, but maybe the issue lies with the type of permissions.
Windows 3.x does support "share-level access control" for CIFS, I think, which is password/folder oriented.
Edit: Or was it the other way round ? 🤷‍♂️
Then, there's the permissions issue on file system basis, but a NAS should take care of it, I suppose.
Re: Windows 98 PC suddenly stopped appearing in the Network on my main (Windows 7) PC
Edit: https://www.paultclark.com/os/nt/samba.html
Reply 2 of 7, by DosFreak
You'll likely need to edit the config file via ssh on the qnap since the interface only has smb1 as a minimum, also you'll need to remember not to make changes in the GUI in the future since it may revert back. The above are just assumptions and I cannot test since I've wiped the qnap os from mine and installed truenas.
Although the functionality isn't gone yet from samba it will eventually so plan for when you won't be able to enable SMB1 and below in the future. If you stick with the qnap os then you can also use ftp or load a VM with its own filesystem or that redirects to your host filesystem.
Make your games work offline
Reply 3 of 7, by SteveC
I wonder if it's now the Windows 3.11 PC that's the problem as I have dug out an old IDE NAS and once I enabled SMB1 on my Win11 PC I can connect to it, but I still can't from the Win3.11 PC.
Yeah I'd rather not edit the config files on the QNAP so I may just ignore that and use FTP after all 😀
Reply 4 of 7, by SteveC
Aha I sussed it! I had to add an entry in to the LMHOSTS file for the QNAP NAS then map a drive by name - Windows 3.11 can't cope with IP addresses!
Reply 5 of 7, by Jo22
SteveC wrote on 2022-09-27, 18:50:
Or maybe it needs WINS to be enabled? Not sure. 🤷‍♂️
Reply 6 of 7, by DosFreak
For truenas I had to enable netbios for sure so makes since that you had to add an entry in the host file if netbios isn't working correctly.
Reply 7 of 7, by SteveC
Jo22 wrote on 2022-09-27, 15:02:
I also did this earlier, but it didn't seem to have any effect, but maybe it also helped.
