Reply 120 of 600, by Joseph_Joestar
- l33t++
Pino wrote on 2022-08-23, 19:27:For sound effects and General MIDI I select the Audigy SB16 emulation on 260/7/3/7/320.
Be advised that some games don't like the SB address being higher than 240 and the MPU-401 port being anything other than 330 (default) or 300.
Another thing I notice is that Line in on the Audigy doesn't seem to be working on DOS and you can't control it through SBEMIXER.
I haven't used Audigy cards in pure DOS much, so maybe someone else can chime in on that. You can check this mixer utility by @PARUS and see if that helps. I have never used it myself, so I can't offer any further guidance besides pointing you in its direction.
