Reply 940 of 1061, by keropi
@ndavis82
there seems to be only one version of win3x driver for the CS4237 - the one mirrored in the Orpheus site
original link: https://web.archive.org/web/20000831055516/ht … odrv/win_3x.cfm
so there is not much to try except the resource conflict investigation
could also worth the effort to do a clean 3x installation and see if something changes , win3x are not exactly the best with hardware/driver changes...
Reply 941 of 1061, by ndavis82
keropi wrote on 2022-10-17, 15:31:
@ndavis82 there seems to be only one version of win3x driver for the CS4237 - the one mirrored in the Orpheus site original link […]
@ndavis82
I already tried a clean installation of Windows, but it did not fix it. I suppose I can try changing the IRQ from 5 to 7 on the card and do another clean installation of Windows 3.1 with IRQ 7 drivers and see if that does anything. Thanks.
Reply 942 of 1061, by ychh0
Joseph_Joestar wrote on 2022-10-17, 06:53:
ychh0 wrote on 2022-10-17, 05:42:
Hello
I wonder if it is possible to drag spdif signal internally from Orpheus. I’m building a PC with Orpheus and Soundblaster Audigy ZS Platinum pro. SB Audigy has 2 pin SPDIF input socket and if it’s possible, I guess Orpheus spdif digital signal can be fed to SB Audigy and sound from Orpheus can be heard from SB Audigy external HUB.
Doesn't the Audigy's external unit have a RCA SPDIF input on the back?
You can use a coaxial SPDIF cable to connect the Orpheus there. I've used this approach to get the SPDIF out of my Aureal Vortex2 card to my Audigy without any issues.
Great. Let me try that. Thanks.
Reply 943 of 1061, by foil_fresh
I'm hearing a noticable audio lag in Quake 2 under Windows 98se, and only in quake 2. All other games seen fine - in DOS and Windows.
I changed the audio settings in quake 2 to low quality and no change. Playing with the sample rate/hardware acceleration sliders in dxdiag doesn't change it either. It's not choppy or laggy audio, just slow to output. Can anyone else test?
FIC-VA503+
K6-2+ 550MHz
128MB SDRAM
Voodoo 3 3000 AGP
Other than this I don't have anything to complain about. It all sounds great.
Reply 944 of 1061, by keropi
@foil_fresh
maybe you need to test another version of the 9x driver? perhaps the one that is faster on 486 systems?
under windows there is not much we can do , we are at the mercy of whatever drivers Crystal released...
Reply 945 of 1061, by Kahenraz
This may not help, but make sure that you have DMA enabled for your hard drive. Maybe there is an I/O bottleneck reading the samples into memory from disk.
Reply 946 of 1061, by Duffman
I'm curious,
How did you eventually decide on the CS4237 chip?
If it was for compatibility Wouldn't something like the Avance Logic ALS120 be just as compatible and also offer SB16 support?
Were there some other reasons to go with the CS4237?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 947 of 1061, by keropi
Duffman wrote on 2022-10-27, 15:07:
I'm curious, How did you eventually decide on the CS4237 chip? If it was for compatibility Wouldn't something like the Avance L […]
I'm curious,
Pretty simple: the CS4237 is capable of great quality output and it's feature set that is used on Orpheus is not available on other chips.
Nothing that Avance Logic produced comes close, they produced chips for the budget market - which is fine and good but not suitable for us.
Reply 948 of 1061, by maxtherabbit
keropi wrote on 2022-10-27, 17:44:
I'm curious,
What's the difference between the CS4236 and CS4237? I have a motherboard with CS4236 onboard and it is excellent
Reply 949 of 1061, by keropi
maxtherabbit wrote on 2022-10-28, 00:16:
from the top of my head main things would be SRS, S/PDIF and depending on the CS4236 revision the cs9236 serial port
Reply 950 of 1061, by alvarok
Orpheus cards (I & II) needs negative 5 volts (-5v)?
I´m building a Pentium MMX based on a Industrial SBC and it does not use -5v, I want to know if it is needed for Orpheus cards.
Thanks!
Reply 951 of 1061, by Marmes
Hello, there is no need for -5v.
Reply 952 of 1061, by logjammer
Any luck with XP/2000?
Reply 953 of 1061, by khyypio
Marmes wrote on 2022-10-29, 22:51:
So, does this mean that Orpheus 1 works flawlessly even if I use a brand new power supply with my retro build?
Reply 954 of 1061, by mrzmaster
khyypio wrote on 2022-11-07, 14:01:
Yes! Can confirm mine works just fine powered by a Corsair CX450M.
Reply 955 of 1061, by chjmartin2
Will the Orpheus work in an 8 bit slot?
Reply 956 of 1061, by IcySon55
chjmartin2 wrote on 2022-11-18, 23:14:
If any of it works, maybe just the OPL3? I don't think it's a supported use case.
Reply 957 of 1061, by smtkr
What does CtrlIRQ do in ORPHEUS.INI? It's set to disabled by default.
Reply 959 of 1061, by 640K!enough
I haven't personally tested it, but this should work fine. The reality is that there is no part of the card that uses 16-bit transfers; the extra "connector" (16-bit ISA) is there only to provide access to DMA 0 and additional IRQ lines (above 7). Using the card in an 8-bit slot shouldn't cause any problems, except that you will be restricted to IRQ 7 or lower and will only be able to use DMA 1 or 3.
