Reply 180 of 453, by Trelokk
Thanks for this useful hint! I removed the battery yesterday and hopefully saved my unit from a premature end this way. Also good to know that the battery is not needed if you are just using it for games. Won't insert it again, then!
Reply 181 of 453, by cricket
Thanks for the useful information.
I'll check my SC55 as well.
The original photo is not shown anymore, what kind of battery is in there?
Reply 183 of 453, by aquishix
SpeedySPCFan wrote:
I had my SC-88 Pro without a battery for a few days since I didn't have any replacements on hand. As a musician, it's really nice to have it in since it saves things like the MIDI OUT/MIDI THRU toggle, instrument patches, etc. But for games it saves absolutely nothing of importance and you can keep it removed.
Good to know that about that toggle on the SC-88. I'm only using this Roland equipment for DOS gaming, but I have an SC-88, SC-55, and MT-32 daisy chained in sequence so that I can use both MIDI inputs on the SC-88 and have the signals cascade to the other modules without having to implement messy switches or fuss with changing cables all the time.
Reply 184 of 453, by twilliamc
I am glad this topic is high up. Should be stickied. I saved my SC-155 from death thanks to this thread.
The attachment battery.jpg is no longer available
Unnamed: 486DX4 @ 120MHz, 16MB, 2GB, 2MB VGA, SBPro 2.0, DOS/W3.11, W95
PC-65:P3 @ 800MHz x2, 512MB, 128GB SSD, Voodoo3, SB Live!, Win98SE
Reply 185 of 453, by Rasna
The batteries in my SC-55, SC-55MK2 and SC-88 Pro had definitely been leaking, no damage to the board and no leaking residue on the blade in the battery holder............
My MIDI modules: Roland MT-32 (old), CM-32L, SC-55, SC-55mk2, SC-88, SC-88 Pro, JV-1010, XV-2020, XV-5080 | Yamaha MU-90, MU-100, SW1000XG, MU-2000EX | Akai SG01k | Hammond GM-1000 | Kawai GMega | Korg NX5R, N1R, Triton Rack
Reply 186 of 453, by Rasna
keropi wrote:
yep both mt-32 and cm-32L that I have opened do use a 7805 regulator since they are 5v devices 😀
I've already replaced them with cooler TSR 1-2450 😀
Reply 187 of 453, by CrossBow777
Does that cause any added noise on the line level outputs that you've heard? I also use these same DC-DC converters in most of my classic gaming consoles. However, when I installed them into the Sega Genesis, I had odd beeps and static that could be heard that was never present before. I also had odd issues with Sonic 3 locking up randomly with them in place. I ended up replacing them back out and putting in higher 2amp versions of the standard 7805 VRs. But that is the only console I've done that with and had issues.
So yeah I'm curious as I have some still on hand and wouldn't mind trying them in my MT-32 or MT-200.
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 188 of 453, by Rasna
I didn't notice any extra noise
Reply 189 of 453, by SpeedySPCFan
keropi wrote:
CR2032 IIRC
I got my SC-55 a few days ago, this is correct - it's a CR2032 battery. Mine was a Toshiba brand specifically - not like it matters, my 88Pro and 55 are now running Energizer batteries so they Keep Going and Going™ 🤣
Musician & music gear/game reviewer.
MIDI hardware: JD-990, SC-55, SC-880, SD-90, VL70-m, Motif ES, Trinity, TS-10, Proteus 2000, XK-6, E6400U
Reply 190 of 453, by Salient
Replaced mine finally as well in both my SC-55's.
They were indeed in poor condition by now, but haven't damaged anything (unlike the Varta stuff in a lot of Amiga's):
Reply 191 of 453, by Baoran
I found my first SC-55 for about 40 euros locally about a week ago and I have not checked the battery.
Reply 192 of 453, by MusicallyInspired
Does anyone know if I would have to worry about this with a CM-500 or MT-200? No, eh? There's no memory features on the CM-500 at all IIRC, and the MT-200 saves everything to floppy disks...again, IIRC.
MT-32 Editor VSTi (wip)
FB-01 tools
Github
SC-55 Packs
Reply 193 of 453, by CrossBow777
MT-200 has a larger tabbed coin battery in it and it is used near as I can tell to save the RTC information in the sequencer. But I would imagine it could go bad and leak like anything else. I took them out of both of the MT-200s I have and installed standard 2032 coin cell holders and put new maxell 2032 batteries in each.
Reply 195 of 453, by Storm82
My recently acquired SC-55 also had a leaking battery. It wasn't much but I still removed it
Reply 196 of 453, by stalk3r
Should one replace it with a rechargeable one, or with a regular Li-ion coin battery (non-rechargeable)?
Reply 197 of 453, by keropi
Use a normal CR-2032 , non-rechargeable
you can also chose not to install a battery at all - it will not hurt playback you just won't be able to save settings. I did not install batteries again in mine since all I am using them are for gaming.
Reply 198 of 453, by stalk3r
Good to know, thanks. I already removed the old one, because it started leaking.
Reply 199 of 453, by DevanWolf
There is another MIDI sound device with a battery backup that is the Casio LD-80 here which runs the internal RAM memory for the custom drum kit setup and drum song recording. Have a look at it:
I did replace the battery with another good one I have and it should work better. The one that is in has a bump in the top and may not work correctly.
