Reply 140 of 555, by Scali
An alternative might be to use threaded jacks and pots, so you can hold the bracket on with those, and no need for 'ears' to screw it onto the PCB.
Reply 141 of 555, by SirNickity
Friendly suggestion: Think about the stresses applied to a card when fastened to the case. I dunno about you guys, but I have a couple of cases where the motherboard / slot fit is uh.. somewhat less than precise. It's probably worth trying to accommodate some compliance into the mechanical mount. Those PITA bracket ears are rigid, but do still offer SOME leeway for the bracket to fit independent of the card. I would really hesitate to use anything soldered to the PCB, as they will bear the brunt of the opposing force if the bracket is not aligned well with the slot. The nylon mounts look OK, but probably won't "give" much.
Now, I've distributed a whopping zero products to the market, so grain of salt and all that. Just some food for thought. If it were my project, I would probably pony up for a well-made bracket with good through-PCB screw mounts, even if it costs more than the PCB to manufacture -- but that's me. I know these things add up quickly.
Reply 142 of 555, by hard1k
Guys, there are several projects already that need brackets. Why not consolidate the demand and make a "golden standard" VOGONS universal bracket to rule them all?..
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 143 of 555, by gdjacobs
I think that would be hard to do. Cards will likely be very different (short of redesigning for a standard back plane), although perhaps a bracket making document would be useful with information for parts and manufacturing.
Reply 145 of 555, by root42
The SnarkBarker also still needs a bracket. Maybe we can find a company that can make both? 😀 And what about the ArGUS?
YouTube and Bonus
Reply 146 of 555, by appiah4
For my Adlib and Snarkbarker I'm getting a couple of these brackets 3D Printer, I will then cut and drill into it with a dremel..
https://www.thingiverse.com/thing:2105827
Reply 147 of 555, by hard1k
But nothing can compare to a good old regular metal bracket... all those 3d printed or PCB-made substitutes are just not true!
AWE64 Legacy
Reply 148 of 555, by keropi
Those "ears" are the most expensive feature to add to a bracket - IMHO unless someone can produce them at a friend's machinery the cost is prohibitive.
The ARGUS approach is also good IMHO -> make the pcb arrangement compatible with the vibra16 cheap cards so you can buy a random eBay card and steal the bracket.
Reply 149 of 555, by Fagear
LABS wrote:
Today I received a first batch of PCBs for the kits in ENIG finish!
Nice! 😎
LABS wrote:
The hardest part was (of cause) making the metal brackets. It took about a month to find a proper solution, because the factory I was hoping for at first, made a sample which was unacceptable. They cut the form somehow ok, but were unable to bend it well. The drilling is in progress right now and the brackets will be ready in 2 days 😀
I probably can make an example brackets for you from FR4 if you'll give me hole positions/sizes. It probably will require some modifications for card, but probably it can be done for the next batch (if there will be any?).
Like this:
361.43 KiB
DuoSID brackets
It holds up pretty well, can provide some flex, conducts to the case like metal one and can be made any in color (from PCB color palette). And it is not expensive.
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 150 of 555, by matze79
Looks very good 😉
Reply 151 of 555, by appiah4
root42 wrote:
I am totally for a SB2.0 clone at this stage. Keep it simple. Learn from this project, and maybe you can later make a SBPro clone. But with SB2.0 compatibility you will already be able to play virtually all games that support AdLib or SoundBlaster. It is just a matter of fidelity (stereo / 16Bit if going for SB16 compatibilitz) and OPL3 support, which is not even supported by many games.
Isn't that basically SnarkBarker?
Reply 152 of 555, by root42
Goodness! This quote is a year old! 😀 by now, yes. The Snark Barker is one option. A very nice one. But I will definitely also build the Blasterboard! 😀
YouTube and Bonus
Reply 153 of 555, by MJay99
I also wouldn't even dare to name the SnarkBarker together with the Blasterboard in terms of its design goal... as much as the SnarkBarker is a very fun thing (and I am very happy with it), the 1:1 clone of the SB also did clone a rather nice noise floor 😁 I'm betting this card is gonna be a world of difference in that aspect, which is why I'm so highly interested in it, too 😀
Reply 154 of 555, by LABS
Finally the brackets are ready and I'm very pleased with the result.
472.16 KiB
326.23 KiB
Blasterboard: DIY SB2-compatible sound card on ATmega MCU
Sonic Buster 8: New 8-bit ISA sound card
Reply 155 of 555, by MJay99
Awesome work! Considering how much time it took to drill and fit a bracket to the SnarkBarker, this is surely gonna be a heaven to put together! 😀
Just a side note, without any real intent to change anything anymore: I just recently found that e.g. Mouser does offer Keystone Brackets with ears, like e.g. the 9202 - it might not fit this version of the PCB, but maybe it could be adapted to fit a future version (if planned). Means it would then maybe just need the remaining drill holes and no fasteners.
Reply 156 of 555, by LABS
Indeed! The guy who drilled them made an awesome work. And these holders are dead-strong. I was sceptical at first and thought they will give the plastic feel, but they actually do not. The bracket sits firmly to the board, just like with 😳 "THE EARS" 😳
Fagear, how do the parts hold together? Glue? I like that the outputs are signed, I really miss it in bb.
Reply 158 of 555, by DosWorld
Hello! Is it possible to bay assembled board ?
CPU: Amd K6/450, RAM: 256M, VIDEO: S3Trio V+, SOUND: EWS64XXL/64M
CPU: iP/100, RAM: 16M, VIDEO: S3Trio V+, SOUND: SB AWE32
IBM Aptiva, CPU i486DX/80, RAM: 96M
Compaq Contura 4/25 2820D, CPU: i486SX/25, RAM: 4M, VGA.
HP 200LX/2M
Reply 159 of 555, by Fagear
Parts are held by fiberglass ledges and solder.
530.17 KiB
Parts are held together by fiberglass and solder
Assembled bracket is attached to the main board either by nuts on connectors (like with metal brackets) or by the same fiberglass ledges and solder.
473.44 KiB
FR4 bracket: held by nuts
972.87 KiB
FR4 bracket: held by fiberglass and solder
560.71 KiB
Mounting points
That's why I told you about some modifications to your "main board". Since there are no connectors with nuts, you have to reserve a little space for large solder pad and add a ledges to the outline of the board.
88.28 KiB
Fiberglass ledge and solder pad
The most physical stress goes into fiberglass ledges, those prevent bracket from sliding away from the board when inserted and pulled out. The same goes for inter-parts connection - fiberglass ledges keep top small piece from been torn away while applying tension to the bracket when installed.
You can screw in the whole assembly into PC case and it will hold the board in slot even without solder at all. But it will fall apart without solder when not inserted.
