Update SC-55 ROM
Reply 20 of 38, by Dusko
Absolutely!. I'm always trying to find the best upgrades I can use on any device, it's my nature, and I have the tools for it, but yes! I'm still happy to have one of the earliest versions!
Thanks.
Retro PC games channel: http://www.youtube.com/@myRetroPC
Electronics, mods and tools channel: https://www.youtube.com/@RetroRust-75
Reddit: https://www.reddit.com/r/MyRetroPC
FaceBook: https://www.facebook.com/myretropc
Reply 21 of 38, by lausvi
keropi wrote on 2018-04-04, 16:54:
IIRC you need a 256kbytes rom so a 27C020 and variants will work fine
Thanks for this, and other pieces of information on this thread!
I just updated my SC55 MkI from 1.20 to 1.21 ROM (using a 27C020). I am not expecting to ever notice the fixes, but I thought why not go all the way and do the upgrade 😁
Reply 22 of 38, by TelamonLivesOn
I've had issues with my SC-55 mk2 when trying to play Blood. The issue is, almost none of the songs play correctly (almost all instruments are wrong, notes won't play, etc.). I just discovered that my SC-55 mk2 ROM version is 1.00. Funny thing is, the setup music works just fine and other games work great. Setting the music to General MIDI or Sound Canvas doesn't change anything either.
Reply 23 of 38, by PC386
for update the Roland SC55 MK1 is just need the PCM.ROM and what about the sample roms are they needed too?
Regards
Reply 24 of 38, by Ripthron
TelamonLivesOn wrote on 2021-02-02, 17:07:
This is a bug in the game, check this thread: Blood and hardware Roland Midi problem
Reply 26 of 38, by keropi
Karmeck wrote on 2024-06-25, 05:17:
Would this one suffice?
https://www.tradera.com/item/408322222
What is that "70" at the end of the name?
yes it will be perfect
-70 is the speed rating in ns - it is a faster eeprom than needed so no issues there
Reply 27 of 38, by Karmeck
keropi wrote on 2024-06-25, 06:23:
So, this was a little big. The seller tells me to bend the legs? Is this a tested method?
Reply 28 of 38, by keropi
Karmeck wrote on 2024-09-17, 12:56:
which is the original chip? the one with the 3 blobs? that looks like a combo chip used for something else...
Reply 29 of 38, by Karmeck
keropi wrote on 2024-09-17, 13:31:
That is somthing els. The shop took the wrong chip. That is a chip from them scc-1A.
Reply 30 of 38, by Karmeck
All is well
Reply 33 of 38, by EmperorGrieferus
arncht wrote on 2025-02-03, 18:47:
I have the v2.00 mk1 with gm marking. What issue should I hear on the games level?
Lack of Capital Tone Fallback. Other than that, it should be fine.
Reply 34 of 38, by arncht
EmperorGrieferus wrote on 2025-02-04, 08:33:
somebody wrote, it is not an issue there.
but anyway, what does the "capital tone fallback" mean?
do you have an example, what i can listen?
Overdoze of the demoscene
Reply 35 of 38, by EmperorGrieferus
arncht wrote on 2025-02-04, 09:44:
somebody wrote, it is not an issue there. […]
Essentially, it means that if the MIDI has variation tone that's not present in SC-55, the module will assign this instrument to its standard variation. 2.00 and mk2, however, won't play the instrument at all.
Reply 36 of 38, by arncht
Ok, so i cannot hear one single instrument, that is it? There are sometimes way bigger differences between the final result (mk1 vs mk2), than this. Eg system shock.
Reply 37 of 38, by EmperorGrieferus
arncht wrote on 2025-02-07, 05:33:
Practically, yes. However, if all channels use inappropriate patch variations, the entire MIDI would be silent.
Reply 38 of 38, by Spikey
The most common scenario is where a composer used the wrong instrument for a drumkit, which means on an original, the correct drumkit is usually still played because of how the SC-55 handles it. On a mkII, it may play the basic Standard drumkit instead, IIRC.
