First post, by serrith
Lo everyone,
I recently bought One unit whole Blood from GOG and the game works in dosbox.
However i also use 2 hardware modules i bought a while ago, a Roland MT-32 (first gen) and a Roland SC-8850.
The Roland SC-8850 works perfectly with the SC-55 map in all the games i tried, but when blood starts it displays a message on the SC-8850 that it hasn't got the instrument and the midi plays completely wrong. If i try it with the other maps (8850 / 88PRO / 88 / 55) it gives the same message and plays the midi wrong.
With my original Blood (without expansion and not GOG) it plays correctly.
I made sure the setup points to the roland soundcanvas or just plain general midi and both give the same wrong results.
Other Build games like shadow warrior and duke nukem 3D work flawlessly with it.
Does anyone know what causes it ? I tried max cycles/fixed/low cycles, dynamic processor, normal etc ...
Any help is welcome.
P.S. My default windows midi device is the Roland UM-ONE, a midi USB converter that is connected to the Roland Sound Canvas.
