MP-32 : Pi based MT32, GM, ... module
Reply 80 of 103, by arthur071169
Hoping this has not stalled. 🙁 on a side note, my SC55 up and died, so now I have zero midi and am reluctant to buy another old unit in case it goes the same way. This project looked to possible offer multi device 'emulation' (Hey, MUNT sounds great and that is definitely software emulation of the physical device). At this point even it it were just a box with decent display, and worked I would be thankful.
Reply 81 of 103, by dreamblaster
still in the pipeline
Thanks for your support !
Reply 82 of 103, by cyclone3d
arthur071169 wrote on 2021-04-22, 13:23:
Did you check the power adapter to make sure it is working?
What about taking the cover off the SC-55 to see if you can see anything obvious provided the power supply is working?
Could even be something as simple as the power plug solder connection cracking.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 83 of 103, by arthur071169
Fantastic news.
I have seen a PI MT32 project that accepts DIN mini in, and uses the bootable slim OS Raspberry PI image (MUNT baked in!), with a HAT for user interface and to allow selection of Soundfont.
This sadly is an ongoing project and no guarantee of when even preorders for the unit can be expected.
It does look great (really!), but no other projects seem to be near completion aside from the Mister PI MT32 project. (again, uses a Raspberry PI and the same bootable image).
It is specifically geared towards a Mister, which is great if you have one, not so great if you are looking to put this alongside a real Dos PC with SBlaster card output to DIN in Midi unit.
Patience is a virtue, and the only thing from making me (ultimately regret) buying another 20+ year old Midi unit.
dreamblaster wrote on 2021-04-22, 19:50:
Reply 84 of 103, by appiah4
Creating a Raspbian install that auto launches Munt and directs USB MIDI to Munt and Munt output to Audio out (or USB DAC) is pretty simple. All you need then is a functional (not a ceapo chinese one) USB MIDI interface. I know you can get the MIDI In via the GPIO headers as well but this setup works for me quite well. I look forward to buying an MP-32 from Serge as soon as this is available though 😀
Reply 85 of 103, by BraveToaster
Is this in any way related to https://github.com/dwhinham/mt32-pi or will it be compatible with that software?
Hardware for that project is also here: https://www.arananet.net/pedidos/product/pi-m … ry-pi-preorder/ - but currently out of stock with no current estimate when it will be sold again, but Edu Arana did tell me that he's planning to sell it again sometime.
Reply 86 of 103, by mihai
I look forward to seeing this project ready to ship, l am ready to buy one; it should have a proper commercial grade enclosure, not loose PCBs.
Reply 87 of 103, by dreamblaster
mihai wrote on 2021-05-04, 10:15:
yes i want to make it a great enclosure
it will take time, it is on hold due to other projects taking priority
Reply 88 of 103, by arthur071169
At this point, I would take a generic or even NO enclosure in order to get the thing up and running and in our hands, with the option to then put it in a customised enclosure when the final design has been completed.
The case could be an upgrade to the device.
dreamblaster wrote on 2021-05-04, 16:45:
Reply 89 of 103, by dreamblaster
arthur071169 wrote on 2021-05-12, 09:59:
would you be interested in a prototype ? pm me
Reply 90 of 103, by dreamblaster
updated pcb
- USB-C input
- DC barrel input with high current switcher
- change to tiny connectors for more elegant connection of buttons and pot
new wires still todo,
Changes to enclosure in progress
Reply 91 of 103, by SScorpio
dreamblaster wrote on 2021-05-15, 14:04:
updated pcb
- USB-C input
Is that used with the MiSTer with a standard USB-C to USB-A cable, or is the port for power or something else?
Reply 92 of 103, by dreamblaster
SScorpio wrote on 2021-05-15, 14:28:
updated pcb
- USB-C input
USB-C is for using a power adapter :
there are 2 power options :
DC barrel jack or USB-C
both option power the board and the pi, so the mp32 only needs 1 power input. (either the usb c adapter of your pi, or a dc barrel adapter)
Reply 93 of 103, by arthur071169
Usb C is much more elegant. Also prevents accidental incorrect power barrel polarity being used.
A great idea to include this as an option.
Reply 94 of 103, by appiah4
Reply 95 of 103, by dreamblaster
it will take more time to perfect the MP32 case
meanwhile i also made an MP32-LITE, which has hat formfactor
maybe that makes sense too? (if there is any interest, will make a separate thread for it, it looks different than MP32, but same principle of course)
Reply 97 of 103, by appiah4
dreamblaster wrote on 2021-05-15, 18:00:
I'm currently building an mt32-pi-midi-hat for myself as a fun soldering project and I'd be more than happy to hear about this, or buy a kit if you have one you want to sell for testing etc.
Reply 98 of 103, by arthur071169
A perfect idea!
Reply 99 of 103, by dreamblaster
ok i create a different thread for this MP32L -> MP32-Lite
This will be ready faster than the full blown MP32
