PCMCIA Sound Cards
Reply 160 of 579, by cyclone3d
Ok... not 100% sure about how stuff is setup when they changed the name to Miles Sound System.
However, if you have a game that has some file that have a .dig extension and uses SETSOUND.EXE to setup the sound device, you should be able to add Wavejammer support to it if it doesn't already support it.
Basically you just get the driver files.
1. All .dig files
2. AILDRVR.LST (you can open this to get instructions on what to select for your card as well as how the card needs to be set up) - Basically select the Wavejammer for digital audio and Adlib for music.
3. Setsound.exe
You probably only need the first 2 but unsure if the different versions of AIL would need different versions of the .DIG files or not.
Just replace those files with the ones from a game that directly supports it and you should be golden.
Here is a supposed list of the games that directly support the Wavejammer.
https://www.mobygames.com/attribute/sheet/att … et,0/p,2/so,0a/
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 161 of 579, by Bondi
Now it's getting more clear. Thnak you!
I have found .dig files and Wavjammer support in Warcraft2, Heroes2 and GTA1.
But there is no .dig file in Abuse for instance, though it's on the list that you put the link to. Maybe WJ support was dropped at some point. Will look into this further.
At least I can see some traces. But I'd prefer to have WJ support in some older games, so that my old laptop that has no bulit in sound could run them.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 162 of 579, by lolo799
Abuse doesn't use the AIL/Miles Design library but the Human Machine Interfaces one instead, that's why there's no .dig files.
The demo version doesn't support the Wavjammer, the full version does:
5.31 KiB
The setup from Destruction Derby, a game using AIL/Miles, as an example of what it looks like:
7.15 KiB
Reply 165 of 579, by Kahenraz
Bondi wrote:
cyclone3d, lolo799, thank you guys!
I'm now waiting for my Wavjammer to arrive to try this all out.
I'm still looking for a dongle for mine, if anyone has one still after losing their card.
Reply 166 of 579, by lolo799
I sent you a possible link for one about a year ago, did you try it?
Reply 167 of 579, by Bondi
So I finally received my Wavjammer card.
It's working fine in DOS as Adlib music source, however I did not manage to set it up for the
games that support it directly.
There are two drivers for DOS - WJSSENAB.EXE and WAVJAMMR.EXE
WJSSENAB.EXE requires only Socket Services loaded. Diagnostic
program detects the card and all tests are passed. It's also possible to set differet port
addresses. The card works in games if Adlib is selected. But the card doesn't work in games
that natively support it. Tried it in Abuse. I can select the card type and port, but test sample
doesn't play and conputer hangs.
WAVJAMMR.EXE requires both Socket Services and Card Services. Then it seems to
configure the card fine, sets port and irq. But Diagnostic program does not detect the card at all.
Let alone the games. It does not even work in Adlib mode.
Any ideas what am I doing wrong?
Edit: I'm using an IBM laptop and tried compatibility command line options - did not help.
Reply 169 of 579, by Bondi
It's an IBM Thinkpad 360CE attached to 3545-001 docking station with a ESS 1868F sound card in it (drivers were not loaded). I still have to try the WJ on the laptop without the dock. Maybe there are some conflicts there anyway. Not sure about the chipset. DOS 7.0 (W95)
There is a mess in config and autoexec now, I have a lot of stuff in there. 😊 I need to clean all up and will post later on today.
Reply 171 of 579, by Bondi
I tried it before, but it said no PCI detected or something like this. It does not detect old chipsets unfortunately.
Reply 172 of 579, by Kahenraz
I believe I followed-up on this but didn't receive a response. I'll try again; thank you.
Reply 173 of 579, by Bondi
Well, here are the config files. Most of the lines are REMed. I tried different cobinations with/out emm386, CS, SS.
config.sys
DEVICE=C:\WINDOWS\HIMEM.SYS
rem DEVICE=C:\DOS\EMM386.EXE NOEMS X=C800-CFFF
rem DEVICE=C:\DOS\EMM386.EXE 2048 X=D000-D7FF
DOS=HIGH,UMB
rem DEVICEHIGH=C:\AUDIODRV\ES1868.COM /A:168 /I:B
REM COUNTRY=007,,C:\DOS\COUNTRY.SYS
rem DEVICE=C:\DOS\DISPLAY.SYS CON=(EGA,,1)
rem INSTALL=C:\DOS\NLSFUNC.EXE C:\DOS\COUNTRY.SYS
rem DEVICE=C:\IBMAUDIO\DIAG\AUDTEST.SYS /V=10
rem DEVICE=C:\IBMAUDIO\AUDIODD\TPAUDDD.SYS
rem rem DEVICE=C:\WINDOWS\IFSHLP.SYS
rem device=C:\WINDOWS\COMMAND\display.sys con=(ega,,1)
rem Country=007,866,C:\WINDOWS\COMMAND\country.sys
DEVICE=C:\IBMVESA\VESA.EXE
DEVICE=C:\THINKPAD\IBMDSS01.SYS /D
DEVICE=C:\THINKPAD\IBMDOSCS.SYS
rem DEVICE=C:\THINKPAD\DICRMU01.SYS /MA=C800-CFFF /SH=1
rem DEVICE=C:\THINKPAD\$ICPMDOS.SYS
rem DEVICE=C:\THINKPAD\AUTODRV.SYS C:\THINKPAD\AUTODRV.INI
rem DEVICE=C:\THINKPAD\DISKDRV.SYS
REM DEVICE=C:\SCP\SCPENA.EXE
rem DEVICE=C:\DOS\SETVER.EXE
LASTDRIVE=Z
rem DEVICE=\PCMCIA\PCMATCD.SYS /D:PCMCD001
rem DEVICE=\CD400\PCMCDSND.SYS /I:11 /P:240 /D:PCMCD001
rem DEVICE=C:\PCAUDIO\PCAUDDD.SYS /IRQ=10
rem DEVICE=C:\DOCKCD\FDCD.SYS /D:IBMCD001
autoexec.bat
rem C:\DOCKCD\MSCDEX /D:IBMCD001 /M:10
rem LH C:\AUDIODRV\ESSCFG.EXE /A:220 /I:7 /D:1 /B:320 /J:E
rem LH C:\AUDIODRV\ESSVOL.EXE /V:12 /L:14 /W:8 /M:0 /C:12 /S:12 /A:0
rem \CD400\MSCDEX /D:PCMCD001
rem SET PS2MSG=C:\THINKPAD\PS2.MSG
rem C:\THINKPAD\FUELDOS
PATH C:\WINDOWS;C:\WINDOWS\COMMAND;C:\DOS;C:\VC
rem PATH C:\WINDOWS;C:\WINDOWS\COMMAND;C:\THINKPAD\;%PATH%
SET TEMP=C:\DOS
rem LH C:\IBMAUDIO\VDD\SVAUDIO.EXE
rem - By Windows Setup - LH C:\DOS\mouse.com
SET BLASTER=A220 I7 D1 P330 T4
rem mode con codepage prepare=((866) C:\WINDOWS\COMMAND\ega3.cpi)
rem mode con codepage select=866
rem keyb ru,,C:\WINDOWS\COMMAND\keybrd3.sys
REM \PCMCIA\MSCDEX /D:PCMCD001
rem vc
Reply 174 of 579, by lolo799
Did you specify the /COMP=GAMES switch as well?
Found this in the wj.hlp file:
13.46 KiB
Reply 175 of 579, by Bondi
Yes, I tried the /c=games switch. But the problem is that only WAVJAMMR.EXE supports this switch. And it still does not work at all. Even in adlib mode.
With WJSSENAB.EXE enabler the card works fine as Adlib; and shows some signs of life at F40 port in WJ native mode. In Abuse setup it produces some sounds, like (Toy.. toy.. toy.. toy..). Now I'm not sure that's the correct sound. If SB is selectet the sample is different, and it does not start with "Toy".
I've tried all obvious combinations of SS, SC, EMM386 with different X= switches, etc.
As of now setup plays "Toy, toy", and the game hangs upon loading.
Reply 176 of 579, by Bondi
Some more experimental data.
I installed Cardsoft (release 5.30.10) drivers. The new thing now is that if I use WAVJAMMR.EXE - it passes all tests in diagnostic program.
Abuse still does not start, but setup does not hang during sound test, but doesn't make sounds either 😀
Still no sound in Adlib mode. 😵
with WJSSENAB.EXE - works as Adlib, as before.
Hope all these experiments do not turture the card too much.
BTW PCMCIA controller is Ricoh RF5C366
Reply 177 of 579, by Bondi
I'm sorry to clutter up this topic with my Wavjammer quest. I don't mind if the TS or moderators move everything to separate thread.
I'm just windering if anyone has actually made the card work in DOS with games that support it directly (i.e. not Adlib, but digital sound)?
