First post, by tabm0de
Im a bit confuse, i was suppost to test a A1330A card on a test station and without drivers the card seems to work fins with example wolf3d ( it says it detects sound blaster and it works ),doom,star wars and so on, i had no idea that it even was possible or am i missing something?
naa, nothing yet...
Reply 2 of 3, by jesolo
Indeed. Under DOS, game and software developers had to write a driver for each type of sound device. You just need to make sure your SET BLASTER environment variable is defined in your Autoexec.bat file, since some games expect it. I won't go into detail about Miles drivers, etc., but this is how it basically works.
Under Windows, it works differently and there you require a driver that must be installed in order for the hardware to function properly within the OS.
