First post, by melbar
I have this sound card:
SC1616
It`s the same model like the sb pro clone from vogons member 'Intel486dx33'
edison gold 16
I have tested this card, FM sound is working, the IDE port has been regierered also by the tool HWinfo610.
But now i want to play some audio streams, from CD-ROM directly. I have installed a Creative 6-speed IDE drive.
On the PCB i can see CD-In headers for Mitsumi, Panasonic and Sony only.
The IDE Audio connector cable is connecting mechanically to the Sony CD-in only. But it's not working.
I think the Pin layout is different between IDE and Sony audio cable.
On a sticker at the back side of IDE drive, there is a symbol of IDE's pin layout:
R- G-G-L
There are also some pin headers directly behind the 3.5mm connectors output (Line-In, Micro and Speaker) .
I've tested to connect at Speaker pin-header , but it is not working either.
I am thinking, that this card is maybe a better Sony/panasonic/Mitsumi card but may not a great card for my IDE drive.... ?!
K6-2/500 [VIA MVP3]
Athlon1200 [VIA KT133]
Celeron1000A [i815EP]
Reply 1 of 8, by cyclone3d
When all the different drives were out, there were CD audio cables available that had all the different connections on one or both ends.
The vogonswiki has a page for the different connectors.
https://www.vogonswiki.com/index.php/CD_audio_connectors
Yamaha YMF7x4 Guide
Reply 2 of 8, by melbar
Thanks for your info.
I have bought this cable.
But i have still problems that i don't hear any sound from a playing audio CD.
Either when it's connected to the Mitsumi CD-In header or the Panasonic header.
About your website you've linked. I am a little confused to be honest.
The cable I've bought, the one end goes to the IDE CDROM.
It's a low height 4-Pin R-G-G-L connector.
Both, the 3-Pin panasonic and the 4-pin Mitsumi are connected to the R-G-L wires.
Looking at the website, for example Mitsumi, there are these wires on the 4-Pin side:
- right channel signal
- right channel return
- left channel signal
- left channel return
No ground?
Looking to all 3 - pin headers , there are:
Texel , Toshiba and NEC.
No Panasonic.
Interesting is that GROUND is on PIN 2 for Texel and NEC , but for Toshiba the GROUND is on Pin 1 .
K6-2/500 [VIA MVP3]
Reply 3 of 8, by vstrakh
melbar wrote on 2022-01-15, 14:13:
Looking at the website, for example Mitsumi, there are these wires on the 4-Pin side: - right channel signal - right channel ret […]
No ground?
The ground is the return path in unbalanced interfaces.
Since your drive doesn't have the balanced output, there's no point in looking at the balanced cable pinout.
Alternatively you can treat the return signals as grounds, and use the cable as is, or shuffle the wires to match your audio card's connector pinout.
Reply 4 of 8, by melbar
I have seen that i've another system with IDE cdrom and audio cable with mitsumi connector.
With this soundcard (opti 929 chipset), the CD- audio signal is working.
I've installed now this "working" cable to the 486 system with the soundcard i've showed at the beginning of this thread, an ISA soundcard with ES688 chipset.
Again it's not working 🙁
I can see also a lot of capacitors on this board.
Is it may possible that bad capacitors can influence this soundcard in that way, that the audio signal is not working, for example ?
But the card's FM sound in games is working ....
K6-2/500 [VIA MVP3]
Reply 6 of 8, by melbar
From my point of view, the only possibility that it's muted , it can be through jumpers.
As you can see the 1st link in this thread, i had shown some pictures of this card some years ago.
The problem is that there are no all jumpers decribed on the backside of this card.
From my point of view, these jumpers are not described:
JP2 , JP6 , JP7 and JP8
Sadly, i've never found any documentation to this card...
K6-2/500 [VIA MVP3]
Reply 7 of 8, by weedeewee
The jumpers you talk about ...
JP2? can't tell
JP6 selection for IRQ 4 5 10 or 11
JP7 and JP8 selection for DMA channel 3 5 or 7 ( these need to be set to the same number)
have nothing to do with cd audio. I think they are only for the cdrom interface connectors, not cd audio.
This is your card right ? http://dosdays.co.uk/topics/images/ess688opl3.jpg or pretty much identical.... slight bit more info can be found http://dosdays.co.uk/topics/Manufacturers/ess.php
are you using it in dos or windows ?
Reply 8 of 8, by melbar
Well, this was my assumption also, that JP 6 ,7 and 8 are for IRQ.... to the CDROM.
But there is also jumper JP, which is pictured at the cards back:
JP3:
IRQ 14 - Primary
IRQ 15 - secondary
Well, i don't care about the CDROM interface on this soundcard, cause i have two IDE port on a controller card.
Yes, the figure you have linked is my model SC1616 rev.1.1
For me it's strange that my Opti929 card is working with the combination: IDE drive - Mitsumi connector
But the SC1616 won't work either to Mitsumi or Panasonic connector...
Actually, i have no idea yet.
I have asked member 'Intel486dx33' here :
( 1995 ) i486DX4-100 “budget Plug-n-Play Win95 build”
He has the same model but called Edison Gold 16.
He hasn't test this card so far.
Edit: No , i'm using pure DOS only - version MS DOS6.22
K6-2/500 [VIA MVP3]
