First post, by stef80
I recently got Diamond Moster 3D that kind of works ... vertical banding is present in 3D scenes and bright backgrounds.
After inspecting the card I noticed one inductor? missing at the back side, close to loop/vga ports. Location in red circle, component L13:
The attachment diamond_monster_3d_back.jpg is no longer available
What spec do I need?
Reply 1 of 14, by stef80
Were there any schematics for these cards ever available? Best I can do is look for the same size component.
Reply 2 of 14, by keropi
no schematics AFAIK
what happens if you restore the L13 connection with a piece of wire?
It's part of the vga signal so nothing bad can happen
I would inspect the front ICs for detached/touching legs
Reply 3 of 14, by stef80
Front ICs look pretty good, except maybe for some dust.
Reply 4 of 14, by stef80
keropi wrote on 2023-01-16, 10:09:
You were right. Looks like whole pad is gone (TMU chip). Will send it to someone with microscope.
The attachment 20230119_193829.jpg is no longer available
The attachment 20230119_211134.jpg is no longer available
Reply 5 of 14, by stef80
Update to this thread: card was actually ok, I had a problem with LCD. All is well after pressing "autosetup" button. Could be a frequency glitch?
TMU pad is actually a factory "defect". There is a small blob of solder on the pin but it is connected to the copper pad.
Ferrite bead was replaced with this one: https://www.ebay.de/itm/274950610818
It's a 1206 package.
The attachment IMG-20230225-111321.jpg is no longer available
The attachment IMG-20230225-112158.jpg is no longer available
Soldering was done by a frend.
Reply 6 of 14, by Ruslan
Hello!
I have non-working Dimond Monster 3D Voodoo. When running Unreal, gives an error that the card is not found. A visual inspection revealed the absence of two electrolytes. The rest of the components are in good condition, the legs of GPU are not bent.
Reply 7 of 14, by Ruslan
I soldered the electrolytes, but it didn't help. The card is still not working.
Reply 8 of 14, by Ruslan
Armed with a multitester, I went through all the components on the board. The inspection revealed some deviations of the resistances of the resistors from the nominal values. But the value of resistor R46, which shows megohms, but should be 0 ohms, turned out to be critical. Also, one of the resistors of the RP23 assembly shows 600 ohms instead of 47.
Reply 9 of 14, by Ruslan
I replaced P46, also unsoldered and resoldered RP23. The resistance became normal, 47 ohms each in the assembly.
Reply 10 of 14, by Ruslan
The card is detected in Windows 98, but Unreal and 3D Mark do not start.
Reply 11 of 14, by Ruslan
Judging by the mojo data, there is still some problem. I didn't find any broken tracks, the radio components are fine. What else could it be?
Reply 12 of 14, by Lostdotfish
Check for loose pins on the FBI, especially along the right edge and the top edge. Also check that the connections on the FBI RAM are good. My recent 0xdead voodoo card had a faulty memory chip on the FBI that was preventing the TMU from being recognised.
Reply 13 of 14, by Gaudeamus83
Ruslan wrote on 2025-11-22, 19:05:
Could you boot straight to DOS, without booting Windows, running cmd prompt under Windows, or dropping from Windows to DOS, then run mojo again?
I have an STB 12MB that was reporting properly in Win98 and mojo (dropped from Win98 to dos). Swapped out with a PA2000 12MB, and this card shows in the cpl fine with all mem and tmu discovered, but dropping from Win98 to dos mojo shows the exact same as yours.
Swapped thr STB back in and it still shows up properly in Win98, but mojo now shows your errors.
Booting straight to dos, both cards report properly in mojo.
K6-III 450 | P5A v1.04 | 768MB PC133 | GeForce2 GTS 64MB | x2 Voodoo2 12MB SLI | Aureal Vortex 2 SuperQuad PCI | DreamBlaster x16GS | 3c905B-TX & ROMOS | CF2IDE | Gotek 435 | Asus 52x CD-R | Tevian SLI Fan Bridge | Rosewill VSB 650W PSU
Reply 14 of 14, by Ruslan
Today I tried to run the card on another computer with Windows XP. Everything worked, I even played a little Unreal.
