First post, by stef80
I recently got Diamond Moster 3D that kind of works ... vertical banding is present in 3D scenes and bright backgrounds.
After inspecting the card I noticed one inductor? missing at the back side, close to loop/vga ports. Location in red circle, component L13:
471.08 KiB
What spec do I need?
Reply 2 of 5, by keropi
no schematics AFAIK
what happens if you restore the L13 connection with a piece of wire?
It's part of the vga signal so nothing bad can happen
I would inspect the front ICs for detached/touching legs
Reply 4 of 5, by stef80
keropi wrote on 2023-01-16, 10:09:
You were right. Looks like whole pad is gone (TMU chip). Will send it to someone with microscope.
811.67 KiB
908.64 KiB
Reply 5 of 5, by stef80
Update to this thread: card was actually ok, I had a problem with LCD. All is well after pressing "autosetup" button. Could be a frequency glitch?
TMU pad is actually a factory "defect". There is a small blob of solder on the pin but it is connected to the copper pad.
Ferrite bead was replaced with this one: https://www.ebay.de/itm/274950610818
It's a 1206 package.
55.39 KiB
41.05 KiB
Soldering was done by a frend.
