First post, by stef80
I recently got Diamond Moster 3D that kind of works ... vertical banding is present in 3D scenes and bright backgrounds.
After inspecting the card I noticed one inductor? missing at the back side, close to loop/vga ports. Location in red circle, component L13:
The attachment diamond_monster_3d_back.jpg is no longer available
What spec do I need?
Reply 1 of 5, by stef80
Were there any schematics for these cards ever available? Best I can do is look for the same size component.
Reply 2 of 5, by keropi
no schematics AFAIK
what happens if you restore the L13 connection with a piece of wire?
It's part of the vga signal so nothing bad can happen
I would inspect the front ICs for detached/touching legs
Reply 3 of 5, by stef80
Front ICs look pretty good, except maybe for some dust.
Reply 4 of 5, by stef80
keropi wrote on 2023-01-16, 10:09:
You were right. Looks like whole pad is gone (TMU chip). Will send it to someone with microscope.
The attachment 20230119_193829.jpg is no longer available
The attachment 20230119_211134.jpg is no longer available
Reply 5 of 5, by stef80
Update to this thread: card was actually ok, I had a problem with LCD. All is well after pressing "autosetup" button. Could be a frequency glitch?
TMU pad is actually a factory "defect". There is a small blob of solder on the pin but it is connected to the copper pad.
Ferrite bead was replaced with this one: https://www.ebay.de/itm/274950610818
It's a 1206 package.
The attachment IMG-20230225-111321.jpg is no longer available
The attachment IMG-20230225-112158.jpg is no longer available
Soldering was done by a frend.
