First post, by smullyoz
Got this nvidia Stereo driver version 12.40
Instead of being an installation file like ive done before, it simply unzips the following to a folder.
Just not sure the way to go to properly install. Do i run all the reg files? Or the exe file? How do i go about installing the inf file? Just right click and install? Do i do all of these steps and in what order or just one of them?
A readme didnt come with the driver.
Reply 1 of 8, by nezwick
I would try installing the driver using the Device Manager tab in System Properties.
Start -> Run sysdm.cpl
or
RIght-click My Computer -> Properties
In the Device Manager tab, double-click on whatever device this driver is for, then on the first tab, click "Reinstall Driver". Follow the instructions in the wizard and point it to the folder that contains these files (specifically NVSTEREO.INF). Finish the wizard and restart your PC. That should do it.
XP: A64 3000+ S754 / 2GB DDR / 500GB SATA / Audigy1
2K: AXP 1700+ @ 1.61 / 1GB DDR / 120GB IDE / X800XL / Audigy 2ZS
98SE: P3 500 / 512MB SDR / 120GB IDE / V3 3000 AGP / Vortex2
95: P200 MMX / 32MB SDR / 3.2GB IDE
DOS/3.11: Acer 1120SX, 386SX-20
Reply 2 of 8, by smullyoz
But im not trying to replace a driver, i want to install the Stereo3D alongside the video drvier.
Reply 3 of 8, by Takedasun
Click on the file NVSTEREO.INF with the right mouse button to display its context menu and choose Install from the context menu.
Reply 4 of 8, by nezwick
smullyoz wrote on 2024-03-21, 22:47:
This Stereoscopic 3D is some type of hardware device, right? USB? So when you plug that in, does it appear as an "unknown" type device in Device Manager? If so, yes technically you aren't "replacing" any driver, you are "installing" one, but that's what WinME calls it. As far as I can remember anyway.
Reply 5 of 8, by smullyoz
No its not a device that appears. Its just a driver, and as long as you have a GeForce card and the 3D glasses you're good to go. So there isnt an unknown device, because there is no device.
You plug in your monitor into the hub, then the hub plugs into your card. The IR emitter is also connected to the hub. The glasses are battery operated.
When i used newer drivers before, or when installing 3D Vision on Windows 7, i install the geforce driver, then i install the stereo driver.
Reply 6 of 8, by smullyoz
Takedasun wrote on 2024-03-21, 23:32:
I guess i can try that. Its just that i have the system nicely setup and stable and everything working nicely and im worried about messing something up with a driver.
Reply 7 of 8, by BitWrangler
IIRC there was also one for the shutter glasses that did the synch through a jack plug in the back of the video card, so if it's for that and the hardware ain't there, then it might not initialise.
Reply 8 of 8, by nezwick
Any luck OP?
