First post, by Badscrew
Hello everybody.
Did anybody try to use this Atari monitor with a PC? I'll be getting a complete Atari 1040 ST + SM147 very soon and being able to reuse this CRT for something else would be nice 😀
Reply 2 of 3, by Jo22
Isn't Atari 640x400 hires output pure TTL/digital ? If so, wouldn't require this a special circuitry to interface it with VGA's analogue RGBHV output ?
Edit: Ok, let me rephrase this. The original SM124 was monochrome and accepted TTL signals only (for better image quality).
http://www.atari-forum.com/viewtopic.php?p=69 … ae304c0b#p69311
So it depends. Does the SM127 contain TTL logic or is it analogue ?
If it is the latter, similat to a mono VGA monitor, it may work.
Some analogue VGA monitors can accept digital (ON/OFF, "fingered") signals just fine,
that's why these simple Atari-VGA screen adapters work the other way round.
Reply 3 of 3, by Badscrew
As far as I know, the 147 has similar circuitry just bigger CRT size (14" instead of 12"). It' expects the same 640x480 70 Hz input as SM124.
