First post, by parhelia512
Hi all ! 😀
I have an old geforce FX 5900 that I would like to save.
Two components are missing at the card back and prevent the card from booting:
I've been able to identify the missing components :
Could someone explain me what are these components, and were could I find new ones to solder on my board ?
Thanks all ! 😀
Reply 1 of 16, by sdz
U501 might be an LMC7211, SOT23-5 package.
As for the other part, most likely a transistor (I think it says Q51 on the silkscreen), but I can't really tell what's written on it before "004"
Reply 2 of 16, by parhelia512
Hello sdz and thanks for your answer.
For the transistor, you are right, PCB says "Q510"
Do you know where I could find these parts ?
Thanks 😀
Reply 3 of 16, by sdz
You can find LMC7211 at mouser, digikey and other major distributors, or on ebay. Just be sure to order the SOT-23 one.
As for Q510, I have no clue what that part is, a better photo would help.
Reply 4 of 16, by parhelia512
Ok, thanks, will try to see if I can find one at a good price.
Concerning the Q510, I have no other picture of it.
Looks like the ASUS FX 5900 as quite the same PCB...maybe it can help identifying the component ?
Reply 5 of 16, by sdz
They are all based on the same reference design, so photos of other cards might help. I googled a bit, but I couldn't find a clear photo of that area.
Reply 6 of 16, by parhelia512
I am trying to read on my board as Q510 and Q512 have the same reference but I can't clearly read what's written 😒
Reply 7 of 16, by sdz
I found the following transistor markings on other cards: A002, A004, A00C. No idea what transistors are those. These might be SM2300NSA.
Reply 8 of 16, by parhelia512
Could be "A004" on mine...Thanks sdz !
If someone can help identifying this transistor, it would be great !
Reply 9 of 16, by sdz
Possible replacement for SM2300NSA would be ZXMN2B14FH. This is also available at major distributors.
Reply 10 of 16, by parhelia512
Thanks sdz for all these usefull information !
Do you know a mouser or digi-key alternative available in Europe ? (shipping cost from USA are 10 times the price of the components).
Thanks !
Reply 11 of 16, by sdz
Both mouser and digikey offer free shipping for orders above 50-60E.
Farnell and RS are distributors located in europe, you can try searching for the parts there.
Reply 12 of 16, by parhelia512
It's really hard for a noob like me to buy electronic components 😀
There are multiple references and they are often sold in high quantities.
Concerning the LMC7211 I can see there is a "simple" or "double" power supply. Do you know which one is the good one for the card ?
Tanks again 😀!
Reply 13 of 16, by sdz
It's just a comparator, it can be used with simple or double power supply as needed. Anyway, on the card it is configured with a simple power supply.
You're welcome and I hope you get the card working 😀
Reply 14 of 16, by parhelia512
I will do my best with all your precious posts !
(the harder is now to find a good provider for the components !)
Thank for all sdz ! 😀
Reply 15 of 16, by sdz
A good provider is farnell, they're from the UK.
LMC7211AIM5/NOPB: farnell code 3005545
ZXMN2B14FH: farnell code 1426252
Reply 16 of 16, by parhelia512
Thanks for the references.
For now the best price I found is around 17€ on the RS website.
Will try to find better as it shouldn't cost more than 3€ for these components I think ?
