My 3DMark03 Mega Thread
Reply 60 of 75, by VooDooMan
ASRock 775-Dual VSTA @ Intel Core 2 Extreme (X6800) at 3075MHz and 2GB of DDR2 RAM testing Radeon HD 3850 AGP.
ECS P6S5AT (SiS 635T)
@ Tualatin-S 1400 MHz SL6BY (512 kb cache 133FSB)
1GB DDR266 RAM (CL 2-2-2-6) on WINDOWS XP! - 2003 3D MARK
Radeon HD 3850 AGP
GeForce 6800 GT
Radeon 9800 PRO 128MB
GeForce 4 Ti 4600
GeForce 3 Ti 500
SiS Xabre 600
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 61 of 75, by bmwsvsu
Custom build:
-Sempron 3000+ (socket 754)
-MSI 7145 motherboard
-1 GB DDR2 Ram (400mhz)
-FireGL v7100 pci-e video card w/256mb vram
Windows XP score - 10,768
Windows 98 score - 10,051 (v7100 card installed as an x800XT)
Reply 62 of 75, by dottoss
For reasons, I did no longer need my router computer, so installed WinXP and tried 3dmark03: 8195
E35M1-I DELUXE
AMD Dual-Core Processor E-350 1.6GHz @2.0GHz
AMD Radeon™ HD 6310 Graphics
4GB DDR3 1666Mhz
Not good enough for me for an Windows XP system, so I need to put the build up for some other use, at some point.
Reply 63 of 75, by Carlos S. M.
Benched my new Windows 2000 system:
Intel Core i7 930
ASUS P6T SE
12 GB DDR3 1333
ATI Radeon HD 5870
2x 500 GB HDD
Windows 2000 Pro SP4 with BWC Extended Kernel and Extended Core
4.3 GHz OC all core + HT:
174.46 KiB
4.3 ghz
Reply 64 of 75, by Standard Def Steve
This cute little Optiplex has teeth! The performance is not bad at all for an OEM business box.
Core i5-4670 @ 3.6GHz
16GB DDR3-1600 9-9-9-24-1T
GTX 1650
Win7 Pro SP1
Very quiet and efficient too.
HTPCs!
Not-a-Gateway-Destination: P2-300 | 192MB EDO | AIW-128 | Dxr2 | 32" JVC D-Series
MCE2005: PM @ 2720 | 2GB DDR2 | GTX 750Ti | BD/HD-DVD combi | 64" F8500 Plasma
Batcave: i7-8700 | RTX 4070 | 32GB DDR4 | JVC 4K D-ILA, 120" AT screen
Reply 65 of 75, by Carlos S. M.
Messing with my VIA C7-D 1800 Mhz and graphing skills, there some results i've gathered at the moment, still working on it
145.8 KiB
Reply 66 of 75, by matze79
Shuttle Mini PC with NForce2 Chipset and 2Gb RAM:
was quiet challenging get this bugger stable.
It only has 200W Power Supply, with the Original 2800 Athlon XP drawing 1,65V (65W TDP) it was not possible getting it stable with the HD3450 installed.
So i replaced the CPU with a Athlon XP-M (45W, 1,45V) and run it at 1.4V giving me the Power for the Radeon AGP Card 😀
Also reduced Heat inside the Case a Lot!
Not so good, CPU won`t run on lower multipler with higher Bus, tried 200/166 etc. only 133Mhz is working fine.
179.41 KiB
https://shadowcircuit.de - german retro computer board
Reply 67 of 75, by Carlos S. M.
matze79 wrote on 2020-06-11, 12:44:
Shuttle Mini PC with NForce2 Chipset and 2Gb RAM: […]
Idk if there are something wrong in your system or not, but seems like either your system isn't performing as expected or the VIA C7-D is actually more powerful than an Athlon XP-M at 1.8 ghz? i just saw and noticed the HD 3450 on my VIA C7-D scored higher and that CPU is slower than the Atom N270 and the P3-S 1400...
Reply 68 of 75, by matze79
The Maximum i got..
195.35 KiB
Patched BIOS with BP, now it does recognize CPU as XP / Barton.
Instantly more Power.
Reply 70 of 75, by SquallStrife
Working on a PC for a retro stream idea I've got floating in my head...
It's a Barton AthlonXP 2600+ with a GeForce FX 5600, on an nForce 2 mobo, does that score seem a bit low to you guys?
Reply 71 of 75, by Shagittarius
SquallStrife wrote on 2022-07-24, 12:00:
Dunno, but here's something for comparison:
98.15 KiB
Reply 73 of 75, by matze79
GTX 1060 3Gb with Ryzen 1600AF
50.58 KiB
Reply 74 of 75, by johnvosh
Same System, 2 different video cards. One is a ATI Radeon 9600 Pro Advantage and the other is a Radeon X800 XL
    210.45 KiB
    159.78 KiB
Sys1: Athlon64 X2 4400+, 2GB DDR400, 150GB WD Velociraptor, Radeon HD 3650 512MB AGP, MSI K8N Neo2 Platinum, XP
Sys2: XP 2500+, 2GB/256MB DDR400, Gigabyte GA-7N400 Pro2, Radeon X800 XL 256MB, SB Audigy SB1394 SB0090, 80GB HDD, ME/XP
Have 3 more systems...
Reply 75 of 75, by johnvosh
Here's 2 runs I did on my newest PC. Dell XPS 8940; i7 11700 @ 2.5GHz, 32GB DDR4 3200, Win 11 Pro, 256GB NVMe Main, 2TB Seagate data, 6TB WD backup, GeForce RTX 3060 12GB
Did one at the stock settings and then one at 1080p w/8X AA. It is very interesting how my CPU score on an 11th Gen i7 CPU (574 CPU score) really isn't that much better than on my Athlon XP 2500+ (522 CPU score). Also interesting how you can't run the sound tests on these new systems, but my old one with a Sound Blaster Live card in it can run them.
    180.03 KiB
    241.15 KiB
