First post, by bjwil1991
I was in the middle of playing Need for Speed: Hot Pursuit 2 on my ultimate Windows 98SE machine, and when I clicked on Quit to menu to change the car controls, the system hung for a few seconds and rebooted.
The display showed artifacts at the POST screen and when the OS was booting and checking the HDD for errors (like always). I then put my GeForce2 MX400 card in place of the GeForce 6200 for the time being, checked to see what the issue was, replaced the thermal compound after cleaning off the old stuff on both the heatsink and the GPU die itself, and I even tested the GPU fan using a 9V battery and some wiring (it still works). How can I give the GPU better airflow to prevent it from overheating? I also downclocked my VooDoo2 card to 75MHz for both Glide and Direct3D since it's installed on an AMD Athlon 64 motherboard.
Reply 1 of 4, by canthearu
Does the 6200 AGP still work properly when cooled down.
Your card might have just up and died. The 6200 AGP isn't a very hot running card, my example doesn't even come with a fan.
Reply 2 of 4, by bjwil1991
The thing is, it's an aftermarket fan since the original heatsink was the heatsink spreader only.
Edit: the card is dead. Refuses to show anything GUI-related (splash screen, OS, the whole 9 yards). The text mode worked somewhat. Now I need to find another GeForce AGP card since the GeForce2 MX400 isn't powerful for Need for Speed: Hot Pursuit 2. I have another GeForce 6200: a PCI variant, which is in another system and my currently installed motherboard has 2 PCI slots that are occupied by the Sound Blaster Live! Platinum 5.1 card, as well as the STB BlackMagic VooDoo2 card.
Good thing I have the GeForce2 MX400 card and it still works, and so does the TnT2 M64 card.
Reply 3 of 4, by canthearu
Yeah, for a 6200, I'd just hold a short funeral and move on with my life 😀
You could try for a Geforce 4 TI4200, or maybe a Geforce 6600GT AGP, if you want something grunty as a replacement 😀
Reply 4 of 4, by nforce4max
There are still plenty of cheap unwanted 6200 AGPs on eBay, no one wants them along with the FX 5200s so easy pickings.
