First post, by Styler
Hi folks.
I recently bought a brand new ATI FireGL X3-256 on ebay. The card itself looks absolutely new and original, but I do have a problem with native FireGL drivers. Whatever FireGL driver I tried to install it thinks that I'm using X800 variation, meaning FireGL OpenGL driver fails on loading (the card shows up as normal ATI FireGL X3-256). With SoftFireGL patches it works perfectly fine. It's worth to notice that not all patches are needed to make it work. As I said the card looks legitimate, with the valid vbios and so on. I didn't disassemble it yet, but I have suspicion that some elements on PCB might be missing or knocked out.
Does anyone have the same card in collection? I'd appreciate if you can take hires pictures of PCB without heat-sink. I tried desperately to find them in the web without luck 🙁
Reply 1 of 18, by lost77
Styler wrote on 2021-04-14, 08:13:
Are you getting an error during driver installation or when you start windows?
Or do games just not work?
Reply 2 of 18, by Styler
Drivers are installed perfectly fine but instead of FireGL panel I got a regular Radeon video drivers panels and all OpenGL games/apps use "OpenGL Microsoft GDI Generic driver", which means atioglgl.dll does not initialize properly due to failing on performing HW FireGL checks. After applying SoftFireGL patches it works as it should.
I use it with Dell Dimension 4600 MT (P4-2.66. i865PE, XP32 SP3). I hardly believe the workstation itself could be the source of the HW validation failure.
Reply 3 of 18, by lost77
The fact that OpenGL games don't work is normal. The FireGL driver is designed for workstation applications so it will only work with a few games (and run slow).
But I don't know why the control panel is the Radeon one.
Please check this Registry key and tell me what is says:
Software\Microsoft\Windows NT\CurrentVersion\OpenGLDrivers\atifglws\
Also, please check the device ID in device manager (VEN_1002&DEV_XXXX)
Did you try the soft mod before using the X3 (on another card)? Maybe it screwed up some registry settings.
Reply 4 of 18, by Styler
No, it's not normal. FGL OpenGL driver atioglgl.dll is actually the same ICD OpenGL but with some DCC oriented improvements. It might introduce some glitches in OpenGL game, but at least it should initialize. This is not a first time when I deal with FireGL cards. I had FGL 8800 at work place back in the day and Radeon 9500 at home which I softmodded to X1. The current behavior of the X3 is exactly as would try to install FireGL drivers on Radeon card with flashed bios from FireGL. There is no drastic difference between X800 PRO and FireGL X3 cards except resistor jumpers on the PCB (as it used to be). They both utilize the same GPU (R420). Since the card looks as a brand new reference X3 card, I suppose there is an issue on PCB and I'd like to compare all components with another working sample of the card.
Dll = Atioglgl.dll
VEN_1002%DEV_4A4D
No, I didn't. I even reinstalled XP to be sure that there is not soft-related issue
Basically, when FireGL driver and cpanel are installed and miniport driver detects a valid card we should have this set of panels in the driver settings. if "Configuration" panel is missing it's a good indication that driver did not recognize your card as FireGL.
Reply 5 of 18, by lost77
Styler wrote on 2021-04-14, 18:45:
VEN_1002%DEV_4A4D
That is the right one so if your card was originally a Radeon is it hard modded to FireGL and should behave as one. EDIT: Not actually sure the Device ID is read from the BIOS or resistors on these cards.
Interesting, none of the FireGL cards I have work with most games with the FireGL OpenGL driver. Phil also did a video of the 8800 and had the same issue.
I can't remember if I got that configuration tab in the display properties, have been a few years. I have 8800, X1 and X2, maybe 8 total. I just use the atioglxx.dll from the Radeon drivers to play games.
I guess they could all be Radeon cards with FireGL BIOS.
Reply 6 of 18, by Styler
yep, I watched Phils videos. As I can see he has exactly the same card (I guess even from the same German seller) and his driver installation process doesn't have the problem unlike mine.
You can note on the video down below that ATI CCC has "Workstation" tab, meaning no issues at all! And yes, of course I tried this driver version with CCC - the same shit.
https://youtu.be/ES7ai6hzuFg?t=461
Reply 7 of 18, by Styler
I took off the heat sink today. Here are some pictures with the BIOS. Looks totally normal, haven't found anything suspicious.. It's based on X850. I guess this should be fine, the same R400 architecture. Have no idea what can be wrong.
Reply 8 of 18, by Lazar81
Hello,
I also have the same card - got it new few month ago. I had several issues with this card. And not enough patience to solve them 🙈.. Maybe I'll try again this week.
Btw: any chance to get it running in Windows 98?
Ryzen 9 5900X - ASUS ROG Crosshair VIII Dark Hero - 32GB RAM - Nvidia GeForce GTX 1080 Ti
Reply 9 of 18, by Styler
You can do it easily ATI x800 And Windows 98 SE
Any driver with X800 support can be used. You Just need to create a new record in drivers inf file or pick existing for X800 adapter and change DEVICE_ID to your card IDs
For example:
[before editing]
"RADEON X800 Series" = ati2mtag_R420, PCI\VEN_1002&DEV_4A4A
"RADEON X800 Series Secondary" = ati2mtag_R420, PCI\VEN_1002&DEV_4A6A
[after editing]
"ATI FireGL X3-256" = ati2mtag_R420, PCI\VEN_1002&DEV_4A4D
"ATI FireGL X3-256 Secondary" = ati2mtag_R420, PCI\VEN_1002&DEV_4A6D
Reply 10 of 18, by Lazar81
Styler wrote on 2021-05-26, 18:36:
>>any chance to get it running in Windows 98? You can do it easily ATI x800 And Windows 98 SE Any driver with X800 support can […]
For example:
[before editing]
[after editing]
Nice...
You are saying example... Means the IDs can vary?
And thx...
Reply 11 of 18, by Styler
If you have exactly the same card as me, then this example is totally valid
Reply 12 of 18, by Lazar81
It's from the german seller bitbull ... They still have much of them
Reply 13 of 18, by Styler
yeap, I bought the card from the same seller
Reply 14 of 18, by dizzydevil
Hello,
I already wanted to buy X3-256 from a German seller, but came across this topic on Vogons.
Could you give me a little more information for me?
Reading the topic, I realized that there would be no problems in Windows 98,
but in Windows XP this video card has problems in games with opengl.
Is this problem solvable?
I read that lost77 used the atioglxx.dll file from the radeon drivers and maybe it works?
If I buy this video card, can I play Windows xp games under opengl?
Reply 15 of 18, by Styler
dizzydevil wrote on 2021-07-21, 05:23:
Hello, […]
Hello,
It's absolutely save to use it with W2K or XP with Radeon drivers. You just need to add your DeviceID to the INF file.
The same method as I described above. I tested it on W9X/W2K/XP - no problems at all.
PS. Sorry couldn't answer to PM (the system does not allow me to do so)
Reply 16 of 18, by Jasin Natael
I have a 8800 and i can confirm that the OpenGL support is mostly nil. Even when you force install the Radeon 8500 drivers, OpenGL doesn't work.
I'm sure that there are ways around it, I've never bothered.
Reply 17 of 18, by Styler
Jasin Natael wrote on 2021-07-30, 20:40:
Most likely there were some traces of the old driver in your system: registry settings, miniport driver and so on. I had FGL 8800 in the past and could use all benefits of Radeon drivers without any issues, since they have exactly the same GPU.
