First post, by murrayman
I’m a little confused on how to properly disable D3D vsync with this card. I’ve got a CT6970 GeForce 256 DDR running on 12.41 in Win98SE and 45.67 on Win2K. Neither of the drivers’ control panels allow you to disable D3D vsync, and PowerStrip 3.20 - despite having the option listed, checking it, then applying the option - doesn’t actually work. Is there some means to disabling D3D vsync beyond installing a newer driver set that slows down performance? I know some of the newer drivers have that option and do work, but if I can get away with not going that route, that’d be preferred.
P3B-F 1.04, PIII 1k, 512MB PC133, GF DDR 32MB + DM3DII 12MB SLI, SB0100
P3B-F 1.03, PIII 700, 384MB PC100, V5 AGP, SB0160
CP 5170, PII 350, 256MB PC100, Rage LT 2MB, ESS 1869
PB M S610, PMMX 233, 128MB EDO66, DM3D 4MB, Aztech
