First post, by murrayman
I’m a little confused on how to properly disable D3D vsync with this card. I’ve got a CT6970 GeForce 256 DDR running on 12.41 in Win98SE and 45.67 on Win2K. Neither of the drivers’ control panels allow you to disable D3D vsync, and PowerStrip 3.20 - despite having the option listed, checking it, then applying the option - doesn’t actually work. Is there some means to disabling D3D vsync beyond installing a newer driver set that slows down performance? I know some of the newer drivers have that option and do work, but if I can get away with not going that route, that’d be preferred.
P3B-F 1.04, PIII 1k, 512MB PC133, GF DDR 32MB + DM3DII 12MB SLI, SB0100
P3B-F 1.03, PIII 700, 384MB PC100, V5 AGP, SB0160
CP 5170, PII 350, 256MB PC100, Rage LT 2MB, ESS 1869
PB M S610, PMMX 233, 128MB EDO66, DM3D 4MB, Aztech
Reply 1 of 11, by Aebtdom
I will soon have a look into it, I grab my old geforce 256 sdr and will try to figure out how it works.
Give me a couple of days.
Builds:
Xp3000+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
P2 350mhz + Diamond Viper V550 + 3Dfx Voodoo 2 12MB + AWE64 + 128MB SDR @ msdos / win98.
Reply 2 of 11, by auron
you need the coolbits registry tweak, it should be easy to find online.
Reply 3 of 11, by havli
Rivatuner perhaps?
Reply 4 of 11, by bloodem
I also recommend the coolbits registry tweak (attached).
Just add to registry and then you will find the VSYNC setting in the nVIDIA Control panel -> Direct3D tab -> Advanced settings
I've been using it for 20 years now and it works perfectly (up to driver version 5x.xx).
Furthermore, it also adds a new overclocking tab.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 5 of 11, by The Serpent Rider
I recommend to use RivaTuner v2.22 for anything Nvidia related starting from Riva TNT.
Reply 6 of 11, by murrayman
Coolbits worked, but for some reason not on any drivers older that 45.23? Don’t know what’s up with that, but I’m running with that now. May try older driver with Rivatuner in the future, or try a different coolbits registry tweak if there’s a separate one for older drivers.
Reply 7 of 11, by The Serpent Rider
RivaTuner can force Vsync on/off switch for Direct3D/OpeGL on pretty much any driver. Maybe with exception for earliest ones, which were made for TNT.
Reply 8 of 11, by bloodem
murrayman wrote on 2021-05-21, 18:22:
It definitely works with any drivers prior to 45.23 (except for very old ones like versions 2.xx). I used it successfully MANY TIMES on driver versions 7.76, 8.05, 12.41, 21.83, 28.32, 30.82, 45.23. (I just used it again 15 minutes ago on 7.76).
You don't need another registry tweak, the one I attached in the previous post should work with all.
Reply 9 of 11, by murrayman
bloodem wrote on 2021-05-21, 19:41:
This is bonkers strange… tried installing 12.41 again (I always do a clean install after using DCPro), then the registry tweak, and it’s still not working. I’m using 12.41 as directly downloaded from Phil’s site too.
Reply 10 of 11, by bloodem
Strange, indeed. Can you also try driver version 7.76? It should be faster, anyway.
It's usually my go-to driver for period correct systems running GeForce 256/GeForce 2 cards.
Reply 11 of 11, by murrayman
bloodem wrote on 2021-05-23, 14:02:
That did the trick, thanks!
