First post, by GooseNipples
Mouser.com tech support was not able to identify it, and r/AMD and r/AskElectronics hasn't come up with an answer either.
Taking my shot in here.
Honestly, I should have come to y'all first :p
It is a surface mount (SMD) capacitor.
https://preview.redd.it/lr72ps0thdc71.jpg?wid … df7c6eda9b716c9
It's the top cap in the group on the left
Sorry if the picture isn't great. I taped it back in place to preserve the location and orientation of the cap
The markings on the cap are:
NA
470
J
363
The card started artifacting badly several years ago. I identified several bulging capacitors (which I have successfully found the replacements for with the help of mouser.com tech support.) and put the card into storage with the intention of recapping it at some point in the future (now, apparently)
At some point when moving it around in my box o' GPUs the surface mount cap in question came off. It cleanly came off the board, so I could actually probably successfully re-attach it to the card as is, but, given how old all the capacitors on his card are, I'd really like to re-cap the whole thing.
The problem lies in that I've thus far been unsuccessful in identifying this cap to find a suitable replacement.
Thank you in advance for any and all assistance
Reply 2 of 7, by bloodem
It’s very hard to believe that bulging caps would cause artifacts. They could, however, contribute to permanent VRAM damage.
Anyway, if you really want to replace the caps, go with Panasonic EEE-FK series, 470uF, 16V. You can’t go wrong. 😀
2 x PGA132 / 5 x Socket 3 / 4 x Socket 7 / 6 x Super Socket 7 / 5 x Slot 1 / 3 x Slot A
5 x Socket 370 / 5 x Socket A / 1 x Socket 478 / 2 x Socket 754 / 3 x Socket 939 / 4 x LGA775 / 1 x LGA1155
Current rig: Ryzen 5 3600X
Backup rig: Core i7 7700k
Reply 3 of 7, by GooseNipples
Someone on reddit pointed me at vgamuseum.info's page on the 9800 Pro.
This is the same config as my card, and the caps are labelled a little differently (better)
http://www.vgamuseum.info/images/zaatharen/at … 9800Pro_fhq.jpg
Looks like they are SMD 470uf 6.3V caps
Someone else mentioned the J means 5% "tolerance"
Anybody have any idea what that means?
Reply 5 of 7, by bloodem
GooseNipples wrote on 2021-07-20, 22:51:
Someone on reddit pointed me at vgamuseum.info's page on the 9800 Pro. This is the same config as my card, and the caps are lab […]
As I said, go with Panasonic EEE-FK series, 470uF, 16V. As long as a capacitor fits, there's nothing wrong with using a higher voltage rating (which is the maximum voltage allowed).
Yes, those original capacitors are most likely rated for a maximum of 6.3V.
Still, don't get your hopes up. Those artifacts that you're seeing are most likely caused by a VRAM issue, or - worst case scenario - by a a faulty GPU.
Reply 6 of 7, by GooseNipples
Thanks everyone for the advice.
I figure, for a few dollars worth of capacitors, it's worth a shot to see if she'll work again.
Even if it just becomes a paperweight on a shelf somewhere, I'll never get rid of it 😀
Reply 7 of 7, by bloodem
GooseNipples wrote on 2021-07-21, 12:07:
I totally understand 😁
