CD Audio sound quiet in DOS mode.
First post, by MrEWhite
So I have a Vortex 2 8830 based sound card and in every DOS game in DOS mode the sound is quiet when I play in DOS mode, but when I play games in Windows the CD audio works fine. Digital CD audio is of course off. I found a work around though, plugging the CD Audio cable in the AUX slot on the Sound card it plays fine in DOS mode. But then I get no CD audio in games in Windows. Is there a fix without the workaround?
Reply 3 of 20, by PhilsComputerLab
Rank Hardware Mod
Hardware Mod
I'd start with the documentation, see if it mentions a mixer application for DOS. Personally I don't use the mixer of sound cards, but an external one. Made a cable that goes from the back of the optical drive into my mixer 😀
YouTube, Facebook, Website
Reply 4 of 20, by MrEWhite
Couldn't find a mixer for it in DOS. Am I SOL?
Reply 7 of 20, by PhilsComputerLab
Rank Hardware Mod
Hardware Mod
The files should get installed when you install the driver. Do a file search on your machine, could be there all along.
Reply 8 of 20, by MrEWhite
Couldnt find anything by the name of Vortmix on my machine.
Reply 11 of 20, by Davros
you did take heed of the following from the readme ?
If you place commands in your AUTOEXEC.BAT, make sure they are AFTER the line which loads the VORTEX DOS Audio Driver.
This program is designed to run in REAL MODE DOS only! Do not run this
program in a Windows95 DOS box.
And you did add the following lines to your autoexec.bat ?
vortmix master 32
vortmix cd 32
Reply 12 of 20, by MrEWhite
Davros wrote:
you did take heed of the following from the readme ? […]
vortmix master 32
vortmix cd 32
Yes, I put it after the dos driver and added "C:\DOS\Vortmix.exe cd 32"
Reply 14 of 20, by MrEWhite
Davros wrote:
does vortmix.exe reside in c:\dos it seems an unusual location for an install program to place files
vortmix is a standalone executable, it doesn't install anything in there. And I just made C:\DOS for my DOS programs, as it didn't exist in the first place on Windows 98.
Reply 15 of 20, by Davros
I was referring to setup.exe or install exe that would install the soundcard drivers and set them up (eg add lines to the autoexec.bat and copy the files to the hdd) from the driver floppy/cd
just like creative labs cards the sb16 copies its files to c:\sb16 i believe and adds lines like C:\SB16\DIAGNOSE /S
Reply 16 of 20, by MrEWhite
Vortmix is a third party executable.
Reply 17 of 20, by Davros
There's no mention in this thread of it being third party
it could easily be the official vortex mixer program
why are you not using the official install floppy/cd for your soundcard that way you would just type setup or install and everything would be set up for you
Reply 18 of 20, by MrEWhite
I'm pretty sure Vortmix is third party in itself, anyways I don't have a CD.
Reply 19 of 20, by Davros
go here and download the file read the page first for all the info
http://www.inetbridge.net/forum/driver-aureal … 830-vt1160.html
link at bottom of page
